914 trunk hinge, broken trunk hinge |
jakedog |
Apr 26 2017, 05:54 AM
Newbie Group: Members Posts: 12 Joined: 8-February 17 From: Brentwood Tennessee Member No.: 20,820 Region Association: None |
I can't find anyone in the Nashville TN area that can fix a bropken hinge on my rear trunk. I bought the item from Pelican to fix it, can't find an actual hinge. I can't figure it out. Thank you
BillC |
Apr 26 2017, 06:46 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Pictures?
FYI, the mounts for the trunk hinges are welded to the body inside the engine compartment, high up on the sides. |
Mark Henry |
Apr 26 2017, 12:03 PM
jakedog |
Apr 26 2017, 01:08 PM
I bought that pivot kit from Pelican. The body guy can't figure how to put in. I'm not handy, that's why I need someone, even in middle tn, to install for me. Thank you |
DRPHIL914 |
Apr 26 2017, 01:53 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
you can install it yourself, no welding required just drilling
burton73 |
Apr 26 2017, 03:30 PM
burton73 Group: Members Posts: 3,512 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
If I remember right you have the wicket spring to deal with.
Bob B |
jakedog |
Apr 26 2017, 06:34 PM
Rand |
Apr 26 2017, 06:54 PM
The jwest kit is super simple. Any shop should be able to do it without needing instructions. But didn't it come with some?
I'd have figured your body guy would say, hell, don't even need that kit, we'll just weld it back up! Maybe it's time to find a better body guy/shop? Certainly Nashville must have one! |
jakedog |
Apr 26 2017, 07:16 PM
The jwest kit is super simple. Any shop should be able to do it without needing instructions. But didn't it come with some? I'd have figured your body guy would say, hell, don't even need that kit, we'll just weld it back up! Maybe it's time to find a better body guy/shop? Certainly Nashville must have one! I’m hoping we do. I’ve not found one yet. Thank you |
falcor75 |
Apr 27 2017, 12:25 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
If you cant find a Porsche shop an aircooled VW shop should be able to do it for you...
jakedog |
Apr 27 2017, 05:51 AM
rgalla9146 |
Apr 27 2017, 05:56 AM
Advanced Member Group: Members Posts: 4,547 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The jwest kit is super simple. Any shop should be able to do it without needing instructions. But didn't it come with some? I'd have figured your body guy would say, hell, don't even need that kit, we'll just weld it back up! Maybe it's time to find a better body guy/shop? Certainly Nashville must have one! The body guy is probably afraid of the torsion bars. |
jakedog |
Apr 27 2017, 12:40 PM
The jwest kit is super simple. Any shop should be able to do it without needing instructions. But didn't it come with some? I'd have figured your body guy would say, hell, don't even need that kit, we'll just weld it back up! Maybe it's time to find a better body guy/shop? Certainly Nashville must have one! The body guy is probably afraid of the torsion bars. He did mention the torsion bars were dangerous |
Rand |
Apr 27 2017, 12:44 PM
I recall jwest saying the kit doesn't require removing the torsion bar?
JawjaPorsche |
Apr 27 2017, 01:45 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I removed my torsion bars because I felt they contributed to the hinge failure. You can use shocks sold by a vendor here. Or I just used a stick. (Really a golf club shaft without the iron.)
GregAmy |
Apr 27 2017, 02:31 PM
Advanced Member Group: Members Posts: 2,286 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The body guy is probably afraid of the torsion bars. Hell, *I* was afraid of the torsion rods... Here's a guy that did it a few weeks ago: http://www.914world.com/bbs2/index.php?showtopic=307730 |
JWest |
Apr 28 2017, 05:29 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I recall jwest saying the kit doesn't require removing the torsion bar? No, torsion bar removal is required. You have to get those out of the way and the hinge arm out of the way to remove the old hinge bracket. What you might be thinking about is that I said not to remove the trunk lid. If it is left in place, the hinge can be positioned while the deck lid is all lined up so there is no trial and error. |
Lo-Fi Version | Time is now: 7th May 2024 - 04:49 AM |
