How to tighten up rear view mirror?, No obvious way |
oakdalecurtis |
Apr 28 2017, 02:11 PM
Oakdalecurtis Group: Members Posts: 1,322 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
How can I tighten up the friction on the front window's rear view mirror. The round connecting section between the window mount and the mirror itself does not seem to be split or have any screw(s) to allow me to tighten it up. Is there a trick to it?
ChrisFoley |
Apr 28 2017, 02:17 PM
I am Tangerine Racing Group: Members Posts: 7,908 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
There's a long flat blade screw that holds the two pieces together.
You should be able to see the screw hole at the bottom of the arm hanging down from the mount. |
oakdalecurtis |
Apr 28 2017, 02:27 PM
burton73 |
Apr 28 2017, 03:02 PM
burton73 Group: Members Posts: 3,486 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Mine is not like yours. There are just 2 parts. Yours looks like it has 3 parts. My unit has the part that goes to the glass and the head of the mirror that has a flip control for day/ night. There is a deep hole that uses a long small screwdriver that Chris spoke of.
Bob B |
914_7T3 |
Apr 28 2017, 04:09 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
There's a long flat blade screw that holds the two pieces together. You should be able to see the screw hole at the bottom of the arm hanging down from the mount. Not my thread, but thanks for the tip as mine requires tightening as well and I have the two piece mirror as described. |
oakdalecurtis |
Apr 28 2017, 05:09 PM
Thanks for trying. Anyone else want to take a stab at it??
Elliot Cannon |
Apr 28 2017, 06:21 PM
Get one of these wide angle things. (IMG:style_emoticons/default/biggrin.gif)
RickS |
Apr 28 2017, 07:07 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I believe one manufacturer of that long mirror is Wink
oakdalecurtis |
Apr 28 2017, 07:59 PM
Can't do the long mirror, have an HD Mirror camera on my mirror. Anyone else know how to tighten this kind of mirror to window connection up?
wndsnd |
Apr 28 2017, 09:30 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
If it doesn't have the adjustment screw, I would order a replacement mirror assembly from one of our parts guys like Garold, or Bruce.
They are relatively cheap and you can remove and install one in minutes. |
Big Len |
Apr 29 2017, 04:34 AM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Can you still use your sun visors with that? |
jim912928 |
Apr 29 2017, 07:31 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I put an 80's era 911 rear view mirror in mine to solve my old worn out 914 one.
bdstone914 |
Apr 29 2017, 07:42 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What am I missing?
Answer: A real 914 mirror. That is not a 914 mirror. Get any stick to the glass mirror to replace it. The type that have a metal divot that glues to the glass and the mirror base slides on. I should have some BMW mirrors that look identical to 914 mirrors. About any mirror from 3, 5 or 7 series BMW from the 80's will work. Bruce |
Front yard mechanic |
Apr 29 2017, 08:10 AM
Senior Member Group: Members Posts: 1,153 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Jb weld
Steve |
Apr 29 2017, 08:18 AM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Amazon sells new 914 mirrors. My screw was stripped and the mirror reflective material was trashed.
Spoke |
Apr 29 2017, 11:24 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
That is not a 914 mirror. Get any stick to the glass mirror to replace it. (IMG:style_emoticons/default/agree.gif) Buy a new mirror at your FLAPS. Your 914 will be no less original with a new generic replacement. You could look for a real 914 mirror if originality is desired. |
TheCabinetmaker |
Apr 30 2017, 12:46 PM
I agree with the others. Not a 914 mirror. its from a 944
ntmatter |
Apr 30 2017, 03:29 PM
Newbie Group: Members Posts: 46 Joined: 10-May 11 From: Gig Harbor, WA Member No.: 13,049 Region Association: None |
For mine, the problem wasn't that the screws weren't tight or were stripped, it was that the thin tin body had holes in it around where the mounting arm was connected, and so even the tightly connected arm didn't keep the window from flapping around - the mirror body vibrated but the arm was tight. So, here's what I did:
1. take the thing apart 2. On the inside vertical side of the body is a fairly thick bracing plate 3. Use JB Weld or similar to bond it tightly to the inside, with a fillet around the edges 4. Let it completely dry and cure, give it a day or so 5. Use new mirror glass if needed, reassemble By doing this my mirror is no longer flapping around limply, it juts out proud, with indefatigueable steeliness. No vibration, and you don't need the adjusting screw on the inside tightened up to 11 so it can be adjusted as needed. |
Elliot Cannon |
Apr 30 2017, 05:42 PM
Can you still use your sun visors with that? No but I had the top of the windshield tinted "limo shade" as far down the windshield as the sun visors would cover. |
Lo-Fi Version | Time is now: 20th April 2024 - 05:57 AM |
