How to tighten up rear view mirror?, No obvious way |
oakdalecurtis |
Apr 28 2017, 02:11 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
How can I tighten up the friction on the front window's rear view mirror. The round connecting section between the window mount and the mirror itself does not seem to be split or have any screw(s) to allow me to tighten it up. Is there a trick to it?
ChrisFoley |
Apr 28 2017, 02:17 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
There's a long flat blade screw that holds the two pieces together.
You should be able to see the screw hole at the bottom of the arm hanging down from the mount. |
914_7T3 |
Apr 28 2017, 04:09 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
There's a long flat blade screw that holds the two pieces together. You should be able to see the screw hole at the bottom of the arm hanging down from the mount. Not my thread, but thanks for the tip as mine requires tightening as well and I have the two piece mirror as described. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:00 PM |
