Rear Brake Caliper Questions |
ljubodraz |
Apr 28 2017, 02:26 PM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
Firstly, many thanks to Eric Shea and the rest of you who have written threads that are helping me rebuild my rear brake calipers on my own.
I've got a few questions so far as I wait for parts: 1. What is the purpose of the mechanism within the brake pistons? Does it allow the piston to extend and retract beyond the limits of the adjustment bolt that threads into it? 2. Is there anything I should do to test that it's working properly? 3. I see that Eric Shea recommends and uses Permatex Ceramic Extreme Brake Parts Lubricant for assembly purposes. I've also seen other threads saying to only use some hard to find $$$ ATE paste. Aside from lubricating the parking brake mechanism that pushes the internal bolt, can't I (should I) simply use brake fluid to lube the pistons and seals during assembly? Unlike Eric's calipers, mine won't be sitting around too long before being installed preventing the brake fluid from absorbing water. |
Jeff Hail |
May 21 2017, 10:25 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Its rather simple actually.
Deflection in the rotor which causes the pads and piston to get retracted ("Knocked back") need to be returned to position. It spring acts as a dampener and helps return the piston to position. The easiest visual aid would be this. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:53 PM |
