D-Jet question, Throttle shaft concern and manifold id |
CatDaddy60 |
Apr 29 2017, 01:02 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
Calling the DJet Ninjas. I picked up this intake manifold a couple of months ago and had some questions first how do you tell the difference between a 1.7 and a 1.8 liter manifold. The second question is on the throttle shaft there is a bit of play, enough that I'm sure this would cause an air/vacuum leak. Should I be concerned about it or is this a non issue. Thanks for your time.
Attached thumbnail(s) |
r_towle |
Apr 29 2017, 09:23 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
any vacuum leak is bad for any of these FI systems.
it can be fixed by drilling out the holes and fitting them with new bronze bushings reamed out to fit the existing shaft... rich |
Lo-Fi Version | Time is now: 17th May 2024 - 06:49 PM |
