D-Jet question, Throttle shaft concern and manifold id |
CatDaddy60 |
Apr 29 2017, 01:02 PM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
Calling the DJet Ninjas. I picked up this intake manifold a couple of months ago and had some questions first how do you tell the difference between a 1.7 and a 1.8 liter manifold. The second question is on the throttle shaft there is a bit of play, enough that I'm sure this would cause an air/vacuum leak. Should I be concerned about it or is this a non issue. Thanks for your time.
Attached thumbnail(s) |
r_towle |
Apr 30 2017, 12:28 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If it moves and is out of spec, you will not have consistent performance.
ANY uncontrolled vacuum leak in ANY efi system needs to be fixed if you want any chance of a decent tune. A loose throttle body shaft is a very common thing to fix in older cars and bikes..... |
Lo-Fi Version | Time is now: 17th May 2024 - 06:57 PM |
