wiring for washer pump switch, am I doing this right? |
914 RZ-1 |
Apr 29 2017, 04:45 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm adding washer fluid pump to my '72. I got a pump and switch. I want to make sure I'm wiring it correctly:
1. Negative on pump goes to ground somewhere on bare metal on car. 2. Positive on pump goes to "LOAD" tab on switch. 3. "EARTH" on switch goes to ground somewhere on bare metal on car. 4. "LOAD" on switch goes to + on pump. 5. "SUPPLY" on switch goes to fuse (#8 or #10, I think), which supplies the power. Is this correct? I got the switch at Radio Shack. It's a "push-to-work" and a light on the switch goes on. It needs to be pushed again to shut it off. I got the pump at Pelican. Thanks! |
Valy |
Apr 29 2017, 05:18 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
It's right but why don't you use a Porsche wiper switch with electric pump activation?
It's been discussed here a lot. Just search my posts on this topic. I'm adding washer fluid pump to my '72. I got a pump and switch. I want to make sure I'm wiring it correctly: 1. Negative on pump goes to ground somewhere on bare metal on car. 2. Positive on pump goes to "LOAD" tab on switch. 3. "EARTH" on switch goes to ground somewhere on bare metal on car. 4. "LOAD" on switch goes to + on pump. 5. "SUPPLY" on switch goes to fuse (#8 or #10, I think), which supplies the power. Is this correct? I got the switch at Radio Shack. It's a "push-to-work" and a light on the switch goes on. It needs to be pushed again to shut it off. I got the pump at Pelican. Thanks! |
Lo-Fi Version | Time is now: 18th May 2024 - 06:38 AM |
