> Stalling until warmed up
chewy71
post Apr 29 2017, 09:52 PM
Hi all. It has been a while. I revived my 914 from an engine fire a couple years ago but it has been sitting idle for about a year. Tomorrow I start my project list, including installing a modern fuse box, finally getting the lights/brakelights to be reliable, steering wheel bushing, new ignition switch, maybe even getting the wipers to work.
It is running well, however I need to let it run for about 5 mins before I can hit the throttle. Otherwise it stalls. After some time passes it runs and drives well.
Running original ljet FI. 1.8 engine. Any suggestions where to go first on the warmup issue?
thanks in advance,
chew
Rand
post Apr 29 2017, 10:14 PM
Cross Member
Maybe send a PM to fellow member ou812 (or it may be gunn1 now or something else.) You have a lot in common.
ChrisFoley
post Apr 30 2017, 08:59 AM
I am Tangerine Racing
QUOTE(Rand @ Apr 30 2017, 12:14 AM) *
Wow Rand, really?
To the OP,
Have you looked for vacuum leaks, checked the filler cap?
Is the ignition timing set correctly?
What's the idle rpm?
Have you tried adjusting the idle mixture?
Rand
post Apr 30 2017, 10:17 AM
Cross Member
I apologize. Gotta close that chapter.
post Apr 30 2017, 12:47 PM
Check your AAR valve. It might be stuck open.
- Lo-Fi Version Time is now: 16th April 2024 - 10:11 AM
