Stalling until warmed up |
chewy71 |
Apr 29 2017, 09:52 PM
Newbie Group: Members Posts: 16 Joined: 16-July 08 From: newjersey Member No.: 9,310 Region Association: None |
Hi all. It has been a while. I revived my 914 from an engine fire a couple years ago but it has been sitting idle for about a year. Tomorrow I start my project list, including installing a modern fuse box, finally getting the lights/brakelights to be reliable, steering wheel bushing, new ignition switch, maybe even getting the wipers to work.
It is running well, however I need to let it run for about 5 mins before I can hit the throttle. Otherwise it stalls. After some time passes it runs and drives well. Running original ljet FI. 1.8 engine. Any suggestions where to go first on the warmup issue? thanks in advance, chew |
Rand |
Apr 29 2017, 10:14 PM
Maybe send a PM to fellow member ou812 (or it may be gunn1 now or something else.) You have a lot in common.
ChrisFoley |
Apr 30 2017, 08:59 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Maybe send a PM to fellow member ou812 (or it may be gunn1 now or something else.) You have a lot in common. Wow Rand, really? To the OP, Have you looked for vacuum leaks, checked the filler cap? Is the ignition timing set correctly? What's the idle rpm? Have you tried adjusting the idle mixture? |
Lo-Fi Version | Time is now: 16th May 2024 - 10:30 AM |
