Replacement Relay Socket Panel, Updated: Version 3 - Solid State Relays and Fuse Panel Replacement |
JoeD |
Aug 15 2017, 02:39 PM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
Yes please!
914_teener |
Aug 15 2017, 03:17 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I.m in after doing my latest "gremlin" project on my car.
Evan0 |
Aug 15 2017, 03:54 PM
Newbie Group: Members Posts: 44 Joined: 13-February 17 From: Southern California Member No.: 20,837 Region Association: Southern California |
Thought of something... While I love the wire color printed on the board, I thought some of the wire colors changed on different years. It may be better to simply label each connection with the original relay pin number (30, 85, 86, 87, 87a). If I were troubleshooting a car with that board installed and I wouldn't want to have to pull out and analyze the wiring diagram to translate wire colors to pin number and function. On the fuse board, it would be prudent to add either a couple extra constant power connections and a couple switched power connections, OR add a couple extra fuses for add-ons. It's not a big deal to add the relay pin number to the labels. But can someone confirm if the relay specific wiring connections changed color from year to year and if the relay wiring is significantly changed year to year? Not a bad idea to add switched and straight battery power to the fuse panel, I'll add that to revision B. Do you guys have opinions on how the fuses should be labeled? Should it indicate the amperage and a function symbol? What would be best to accommodate cars from different years? |
euro911 |
Aug 15 2017, 04:05 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) ... All of the above mentioned items:
Fuse position # ... 1 ~ Fuse rating for each position Function symbol for each fuse position would be nice too A couple extra fuse slots labeled 'AUX' |
JeffBowlsby |
Aug 15 2017, 10:05 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Yes different MY 914s have different fusepanel and relay circuitry. Fuse amperages and layouts changes too.
KISS. Just number the fuses 1-12 just like the factory schematics. someone else can figure out what goes where for the different years. |
Evan0 |
Aug 16 2017, 12:04 AM
Another question, how critical is the angle on the fuse panel in relation to the harness bundle? Would removing the tilt negatively affect strain relief on the harness? Optimizing the design for injection molding with that angle is proving to be a pain and removing that tilt would solve many issues. Thanks.
Spoke |
Aug 16 2017, 06:48 AM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Beautiful design. Looks really well thought out. Lots of good feedback from the guys too.
One question on the placement of SSR U6 for the low beam: Why is it turned around WRT to the other SSRs? With it's positioning, its exposed pad is not against the heatsink. Was this done for isolation? What is the theta-JC from junction to the EP versus junction to top of case? |
JeffBowlsby |
Aug 16 2017, 08:32 AM
I amm pretty sure - not positive - that the slant is to enable a better viewing angle of the fuses where it is mounted. As long as the terminals are oriented normal to the back of fuse panel there is no unusual strain condition at each terminal
Wondering...what is intended for a fuse panel cover? The stock cover indicates the functions of each fuse. |
914work |
Aug 16 2017, 08:42 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Wow cant believe I missed this thread.
Extremely nice work and commend your willingness to accept & incorporate the feedback !!! Put me on the list~ |
76-914 |
Aug 16 2017, 08:51 AM
(IMG:style_emoticons/default/agree.gif) Impressive! (IMG:style_emoticons/default/beerchug.gif)
VaccaRabite |
Aug 16 2017, 08:58 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Want want want want want.
Seriously. I want this. Zach |
Evan0 |
Aug 16 2017, 10:33 AM
One question on the placement of SSR U6 for the low beam: Why is it turned around WRT to the other SSRs? With it's positioning, its exposed pad is not against the heatsink. Was this done for isolation? What is the theta-JC from junction to the EP versus junction to top of case? I'm regretting the placement of U6 and it going to get flipped around for the next revision. I'll need to move a couple other components around to make that happen. I had it in that orientation originally to simplify routing. 7mm thick traces on both side are required to meet my current and temperature requirements, so routing was a bit of an issue. Thermal resistance junction to case is 0.3°C/W and junction to ambient is 33°C/W. The heatsink is approximately 28°C/W. I'm going to run a thermal test with a thermal camera with three of the relays carrying 12A, which should reflect worse case real world use. I'll incorporate anything learned from that test in the next revision. Wondering...what is intended for a fuse panel cover? The stock cover indicates the functions of each fuse. Thanks for answering my question. If its not critical to the connecting terminals, I think i will straighten it out to make injection molding much easier and cheaper. Is there a source for the stock cover? If reproductions are available, I would like to go with those to maintain some look of originality. |
JWest |
Aug 16 2017, 10:37 AM
"3. The new fuseblocks do not have the bussed together lugs that the factory fuseblocks do, so makeshift additional terminal busses are needed or the circuitry is altered to accommodate, making the factory wiring schematic useless for troubleshooting."
This statement is not true. Engman had a flaw in his process of doing it, from what I understand, but did have it. Maybe he sold some without it? Mine have always been bussed just like factory and it is the most difficult part of manufacturing these, since they have to be fully disassembled and modified internally. But irrelevant if this makes it into production. I am all for a better design, as I am not willing to put in the time to design a fuse box from scratch and the connection positioning is not optimal for the stock harness to bend around to reach. I keep it going since there is nothing better on the market. Let me know when this makes it to retail sale and I'll push customers to it (or resell on my site if that is of interest to you). |
914_teener |
Aug 16 2017, 02:50 PM
One question on the placement of SSR U6 for the low beam: Why is it turned around WRT to the other SSRs? With it's positioning, its exposed pad is not against the heatsink. Was this done for isolation? What is the theta-JC from junction to the EP versus junction to top of case? I'm regretting the placement of U6 and it going to get flipped around for the next revision. I'll need to move a couple other components around to make that happen. I had it in that orientation originally to simplify routing. 7mm thick traces on both side are required to meet my current and temperature requirements, so routing was a bit of an issue. Thermal resistance junction to case is 0.3°C/W and junction to ambient is 33°C/W. The heatsink is approximately 28°C/W. I'm going to run a thermal test with a thermal camera with three of the relays carrying 12A, which should reflect worse case real world use. I'll incorporate anything learned from that test in the next revision. Wondering...what is intended for a fuse panel cover? The stock cover indicates the functions of each fuse. Thanks for answering my question. If its not critical to the connecting terminals, I think i will straighten it out to make injection molding much easier and cheaper. Is there a source for the stock cover? If reproductions are available, I would like to go with those to maintain some look of originality. Personally I think the stock cover is not practical. Why not a sticker or silk screen over a cover One has to pull the fuse anyway to check it. .I.m with Jeff...KISS. |
Spoke |
Aug 16 2017, 04:18 PM
I'm regretting the placement of U6 and it going to get flipped around for the next revision. Very few products make it to production with Rev 1. I recently did a PCB for the people mover trains at Newark Airport where I reversed the coil leads for 6 relays. (IMG:style_emoticons/default/dry.gif). Fixed it in Rev 2. |
Evan0 |
Aug 26 2017, 02:40 PM
Update 8/26/2017
Been on vacation for the last couple weeks so not much progress. I did get around to doing a thermal test of the relay board. Here's a picture of the test setup. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1503780005.1.jpg) A 12V 600W power supply provides the juice to drive current through the solid state relays. Three 1Ω 200W resistors provide the load for the test. The fog, air fan, and low beam relays were chosen to as the test subjects since they are the high current draw items. The resistors actually measured about 1.2Ω so with 12V it should provide 10A through each of the relays. Left it running for about 20 minutes to reach steady state. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1503780005.2.jpg) The max measured temperature was about 91°F, 15°F above ambient. Looks like the heatsink is doing its job correctly. The load resistors did get quite toasty during the test run. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-20837-1503780005.3.jpg) With 30A passing through the PCB and the relays, there doesn't seem to by any issues. With these results I'll get to work with Rev B and figuring out how to mass produce these at a reasonable cost. |
davehg |
Nov 14 2017, 05:49 PM
Member Group: Members Posts: 182 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
Any updates on this? I'm a few months away from tackling the electrical portions of my restoration and would love to commit to a fuse block solution.
mb911 |
Nov 14 2017, 07:17 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
This is a very cool project.. I would be interested.
Larmo63 |
Nov 14 2017, 07:48 PM
I'm glad there are people in this world who are smart enough to know this stuff.
I have my own skill set, and I'm really good at Jeopardy, but thank you for making me feel like a complete nincompoop. |
Nov 14 2017, 08:04 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm glad there are people in this world who are smart enough to know this stuff. I have my own skill set, and I'm really good at Jeopardy, but thank you for making me feel like a complete nincompoop. I had a great feeling of accomplishment when I screwed the shift knob Zach had made for me, into the rennshifter lever. Righty tightly, lefty loosey. |
Lo-Fi Version | Time is now: 24th April 2024 - 11:07 PM |
