Fan housing blockoff, no heat |
MattR |
May 9 2005, 01:08 PM
From what I understand of the 914 heating system, the fan housing outlets have to be blocked off if I'm not running heat. Can anyone give suggestions on how to block these off? I could weld them up, but Im not sure about the material, and I'd like to be able to seperate the fan housing without grinding and rewelding.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1110132454.jpg) (those outlets at the bottom) |
Mueller |
May 9 2005, 01:14 PM
don't laugh at my "solution" (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I cut a few pieces of wood, shoved those into the openings, used RTV for a seal and drilled a hole into the bottom of the housing and used a wood screw to secure the wood block into place (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
tat2dphreak |
May 9 2005, 01:15 PM
don't block them, everything I've heard said that causes an "air disturbance" jus leave 'em be...
or figure out a way to use them for something else... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) tubing to help cool the back cylinders more? |
MattR |
May 9 2005, 01:17 PM
Sorry mike, Im not putting wood in my car (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I like the idea of tubing. I can chop up a stock piece and divert it with some rubber hose or something over the back cylinders? It probably wont do anything, but help with "peace of mind" |
May 9 2005, 01:20 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
flat piece of aluminum and epoxy works just fine ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Mueller |
May 9 2005, 01:21 PM
nobody has to know (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
mike_the_man |
May 9 2005, 01:26 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
At least it won't rust! (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Cap'n Krusty |
May 9 2005, 01:28 PM
NOT blocking them means a SUBSTANTIAL percentage of the available cooling air goes away, something you don't want to happen. Whatever method you use, they need to be blocked. The Cap'n
MattR |
May 9 2005, 01:31 PM
I dont want termites though (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) I was just thinking about maybe drilling some holes and mounting a thin piece of flexable sheet metal to the inside to maintain the contour of the housing. If it works the way I want, i'll post pics next weekend. |
TravisNeff |
May 9 2005, 01:33 PM
Duct Tape will work in a pinch!
Mueller |
May 9 2005, 01:35 PM
actually, mine won't be food for termites or be subject to water damage or anything like that...I sprayed them with a silicon rubber protection coating.......... |
maf914 |
May 9 2005, 01:42 PM
How about filling them flush on the inside so the fan will see a smooth scroll case where the vents used to be? You could use wood or rigid foam with epoxy, or maybe urethane spray foam to form the plug in each case half then bolt it together.
McMark |
May 9 2005, 01:49 PM
Mine have been open 100% of the time and I haven't seen high oil temps. Even will all the spirited driving at the WCC.
Duct tape will not work. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) That's what I tried originally and it came off almost instantly with all the heat. If I were going to plug them off, I'd use aluminum and epoxy. |
TravisNeff |
May 9 2005, 02:07 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I had mine clean and painted, duct tape held on for a phoenix summer of driving
Joseph Mills |
May 9 2005, 02:17 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Mine are blocked off with duct tape. Works great.
But didn't we just have a thread discussing the fact that blocking these vents is detrimental to the air flow? It was stated that the flow needs to continue to and thru the heat exchangers? Or am I just trippin'? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Rand |
May 9 2005, 02:19 PM
You didn't reinforce it with bailing wire! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Help a noob... I'm missing something. Opening these flaps is how the heater is fed, right? (Ducting hot air to the cabin?) Or are these the thermostatically-controlled cooling flaps, different from the driver-controlled heater flaps? Can the flaps themselves be closed, fastened, and sealed with a heat-proof sealer around the perimeter? |
Mueller |
May 9 2005, 02:22 PM
headers, no need for the ducting (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) if running heat exchangers, I'd think you'd want some air to blow thru them for cooling of the heat exhangers........... |
tat2dphreak |
May 9 2005, 02:35 PM
why do you want to cool off your H/Es... hotter the better(to an extent), hot air moves faster... which is good for exhaust... Jake was the one saying that blocking these off is detrimental to airflow, it causes an extra turbulence which will increase head temps... the heads don't get as much air, because of the turbulence created when blocking these off... better to leave them open, with air going no where... I think something can be done to rout this air from these holes to help the head temps... I just don't know how yet... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) the way mcMark has it now is right, which is why he isn't seeing temps climb, (though I think it would affect the head temps, not oil if the holes are plugged) |
Mueller |
May 9 2005, 02:39 PM
tell that to the poor souls that own 2.7 powered 911's in the early days, hot air goes up, straight to heads (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Rand |
May 9 2005, 02:45 PM
Trying to learn here...
Are these flaps the ones controlled by the thermostat for cooling, or by the driver to feed the heat ducts? |
Lo-Fi Version | Time is now: 29th April 2024 - 05:54 AM |
