Tuner?, Central Oho |
80cap |
May 1 2017, 02:15 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Anyone know of a engine tuner in Central Ohio? New rebuilt 2056 engine with
Dellorto, Web Cam, Etc. I have a misfire on number 3 cylinder. It is at 2 to 3 thousand RPM. and it is intermittent. It is on a run stand so everything is right in front and center. I would guess it is in the carb. Brian (IMG:style_emoticons/default/headbang.gif) |
North Coast Jim |
May 2 2017, 06:59 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Anyone know of a engine tuner in Central Ohio? New rebuilt 2056 engine with Dellorto, Web Cam, Etc. I have a misfire on number 3 cylinder. It is at 2 to 3 thousand RPM. and it is intermittent. It is on a run stand so everything is right in front and center. I would guess it is in the carb. Brian (IMG:style_emoticons/default/headbang.gif) PM me I may have a source for you |
ChrisFoley |
May 2 2017, 07:46 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
At that rpm on a test stand, an intermittent miss possibly means your idle jets are undersize.
It isn't possible to tune the main circuit without a significant load on the engine. |
80cap |
May 2 2017, 08:37 AM
I swapped the carbs left to right and the miss and popping followed the carb. So I guess I need a Dellorto guy.
Brian |
Lo-Fi Version | Time is now: 18th May 2024 - 03:25 AM |
