Bottom oil line on 914/6 oil tank.... |
xitspd |
May 10 2005, 07:20 AM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Your right! My post deleted! |
Carl |
May 10 2005, 10:01 AM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
Michel, Do you have a spec on the hose and the name of the place where you found it? My brother couldn't find one locally and even tried to buy a replacement hose from Porsche. They quoted an outrageous price and never delivered it even after waiting for months. |
michel richard |
May 10 2005, 10:06 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I probably have some left over. I'll look in the garage tonight and provide details.
Carl |
May 10 2005, 10:10 AM
Great! Thanks! I'd like to have some available for the next time it leaks. |
Gint |
May 10 2005, 10:14 AM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Yeah, same here! |
Porsche Rescue |
May 10 2005, 10:25 AM
And me too.
Carl, should I decide to try the "re-seal" approach, where exactly do I apply the sealer? On the outer surface of the hose before re-inserting into the fitting? Thanks very much for the detailed info. and pictures. I had no idea that the rubber hose could be separated from the aluminum fittings. |
Carl |
May 10 2005, 10:34 AM
Hi Jim,
Since the hose end comes into contact with a large surface area of both the inner and outer fittings then the sealer can be applied to both surfaces of the hose. Obviously, the risk of getting sealer into the engine is greater if there's excess on the inner surface. |
michel richard |
May 10 2005, 07:10 PM
OK, I don't have any of the supply hose left. I think I threw out what I had left, and what's on the car does'nt have markings. I remember it was relatively expensive stuff: armored (steel mesh) thin wall construction, so it would be flexible. I've got a few shots of my setup that follow. Further down will be shots fo the return line, with the markings clearly shown.
HTH Michel Richard 914/6 2.2E MFI Attached thumbnail(s) |
michel richard |
May 10 2005, 07:11 PM
Previous shpt may not speak much. Sorry. Here's the tank end of the supply line.
michel richard |
Oops
michel richard |
May 10 2005, 07:12 PM
Her's how my supply line connects to the elbow
michel richard |
May 10 2005, 07:13 PM
And then on to the engine. I addd a drain fitting, to change the oil.
michel richard |
May 10 2005, 07:14 PM
Good news is, the return line has clear markings:
michel richard |
May 10 2005, 07:15 PM
I'm in Canada, and I love stuff made in the USA, including this site !
Here's a broader shot of the return line: Attached thumbnail(s) |
michel richard |
May 10 2005, 07:16 PM
Where it goes through the engine shelf of driver's side:
michel richard |
May 10 2005, 07:19 PM
In the last shot, the aluminum you see is a sleeve I added in addition to the fitting at the end of the line, to keep the hose from rubbing on the shelf.
Here's the other end of the scavenge hose, where it connects to a Porsche fitting, on the passenger side of the engine. This fitting connects to an elbow and to the engine crankcase. Attached thumbnail(s) |
michel richard |
May 10 2005, 07:23 PM
In setting these up, my thought was that a lot of the steel braied lines we see are massive overkill. These line see only a little more than atmospheric pressure, so using fittings and line that are rated above 100 psi is more than enough. A lot of the stuff that is used in convrsions is rated at thousands of psi, which is a pure waste. IMO.
Once again, I hope this helps. |
Porsche Rescue |
So the supply and return hoses are a different size?
michel richard |
May 10 2005, 07:28 PM
I guess they are. I'll go and measure, be back in a couple of secs.
michel richard |
May 10 2005, 07:41 PM
The supply hose is 1.250 O.D. Here's a shot, for fun
Lo-Fi Version | Time is now: 29th April 2024 - 03:08 PM |
