Bottom oil line on 914/6 oil tank.... |
michel richard |
May 10 2005, 07:42 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
The return line is 1.050 O.D. I added a shot of the elbow at the engine end.
Attached thumbnail(s) |
michel richard |
May 10 2005, 07:44 PM
Note that none of the fitting-to-hose connections show any oil stains - somewhat proud of that.
Porsche Rescue |
May 10 2005, 07:47 PM
Thanks a lot for all your good info and pics.
michel richard |
May 10 2005, 07:51 PM
This is the place where I got the hose. The owner probably can speak some English, but I'm not positive. Saint-Constant is a suburb of Montreal. I doubt he would remember me, although I've been there a few times and he sort of recognizes me when I show up. The worst that can happen if you phone him up is that you will waste the long distance charges. Canadian and US phone systems are integated. You dial "1", then the area code.
Duroy Pièces d'Autos inc. 264 Route 132, Saint-Constant, Québec J5A 2C9 (450)632-9871 (450)632-5272 Fax |
Gint |
May 10 2005, 08:05 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Thanks Michel! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
J P Stein |
May 10 2005, 09:09 PM
I put enuff pressure on my scavenge line to blow my Aux cooler (one of my glorius fuckups). I talked to a guy(racer) that had a pressure gage rigged on his scavenge line. He reported up to 165 psi on it with a cold engine.....that's bout 10 bar, slightly over atmospheric, I'd say. GPR used to sell a 2 piece feed line that is similar to the stocker.....steel fittings at each end. |
Carl |
May 10 2005, 11:58 PM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
Thanks for the pics, Michel. You've got a clean install with no leaks. Congrats!
Your setup is different in several respects. The replacement hose we've looked for is the supply line. If you find a vendor for that I'd sure like to know about it. |
michel richard |
May 11 2005, 05:14 AM
I'll see if I can get details after all.
Michel |
michel richard |
May 11 2005, 05:17 AM
I stand corrected, but I suspect that the presence of an auxiliary cooler changes things significantly. In any event, the scavenge line I use, as you can see, is rated to 350 psi, the supply is even higher. Michel |
J P Stein |
May 11 2005, 06:53 AM
You are correct, aux coolers were involved.
The SS braided lines may be overkill, but one can fab the lines in the comfort of one's own garage and I found that I had to fab the aux cooler lines "in place"......run the lines then add the fittings. |
Lo-Fi Version | Time is now: 29th April 2024 - 05:32 PM |
