| HalfMoon |
May 5 2017, 05:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Sooo...it's come time to refurbish my front suspension. I don't need to do tie rods or sway bar bushings and I'm not going to work on the steering rack yet, so this'll be a "partial" rebuild.
I did some searching but really couldn't find a comprehensive guide to rebuilding the 914 front suspension. Does anyone have a link to something? I gather what I'll be doing is the torsion bar bushings, the wheel bearings and the ball joints? Are their more bushings and or bearings that I haven't included? Thanks all! |
| mepstein |
May 5 2017, 06:40 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Turbo tie rods, front strut inserts, new brake soft lines, bleed brakes, check brake pads. Sway bar bushings?
| jmitro |
May 6 2017, 06:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
this has every possible item that needs attention in the front suspension.
obviously brakes and steering rack are not suspension items but you get the idea.... http://www.elephantracing.com/suspension/d...siondiagram.htm |
| HalfMoon |
May 6 2017, 03:51 PM
this has every possible item that needs attention in the front suspension. obviously brakes and steering rack are not suspension items but you get the idea.... http://www.elephantracing.com/suspension/d...siondiagram.htm Thanks for that link. It's quite helpful. (IMG:style_emoticons/default/beer.gif) |
| HalfMoon |
May 6 2017, 05:18 PM
Sooooo, pretty much the (4) control arm bushings, wheel bearings and (2)ball joints.
I wonder what the consensus is on the control arm bushings? Obviously the gee whiz bronze bushings are the tits, but other than that, rubber or poly? Also, I saw a nice enough ball joint kit at the bird offered by Rennline but no customer comments. Anyone have feedback on that kit? |
| michael7810 |
May 6 2017, 07:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
I'm happy with the rubber bushings from Elephant
| GeorgeRud |
May 6 2017, 07:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Unless you're racing the car, stick with the rubber. There's a reason Porsche used it initially and it's served well for 40+ years.
| HalfMoon |
May 6 2017, 07:36 PM
I'm happy with the rubber bushings from Elephant Yes, I just watched they're video. I trust the included tools made the job quite a bit easier? I don't suppose you'd loan em out would ya? Btw, in the video they use a digital angle tool. What did you use to index them? Thanks! |
| michael7810 |
May 7 2017, 07:02 AM
I'm happy with the rubber bushings from Elephant Yes, I just watched they're video. I trust the included tools made the job quite a bit easier? I don't suppose you'd loan em out would ya? Btw, in the video they use a digital angle tool. What did you use to index them? Thanks! The iPhone and probably non-Apple smart phones have a app to measure the angle. Be careful you get the correct orientation for the 914; IIRC the video is a 911 part and if you set it up exactly like it's shown it ends going the wrong direction by 90 degrees. Ask me how I know (IMG:style_emoticons/default/blink.gif) Luckily the soap had not dried and it was easy to reclock them. PM me your info if you want to borrow the tools. |
| HalfMoon |
May 7 2017, 07:37 AM
I'm happy with the rubber bushings from Elephant Yes, I just watched they're video. I trust the included tools made the job quite a bit easier? I don't suppose you'd loan em out would ya? Btw, in the video they use a digital angle tool. What did you use to index them? Thanks! The iPhone and probably non-Apple smart phones have a app to measure the angle. Be careful you get the correct orientation for the 914; IIRC the video is a 911 part and if you set it up exactly like it's shown it ends going the wrong direction by 90 degrees. Ask me how I know (IMG:style_emoticons/default/blink.gif) Luckily the soap had not dried and it was easy to reclock them. PM me your info if you want to borrow the tools. Chuckle, I'm still with a dumb phone. And I'm thinking I'll mebbe just do ball joints as the control arm bushings don't look so bad. Pretty sure my wobble is coming from the ball joints :-/ If I decide to do the bushings though, you can be sure I'll be in touch for the loaners! You're an ace my friend :-) |
| BillC |
May 8 2017, 09:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 750 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
I'm going to be replacing the control arm bushings and ball joints in my front suspension soon, so I thought I'd tag onto this very-relevant thread.
Has anyone used the URO front bushings? Are they okay? Besides being from URO, that is. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/blink.gif) Pelican has them for $30/set, which is quite a bit cheaper than the Elephant parts. Or, are the Elephant rubber bushings just so much better than the others that they're worth the extra $$$? I don't really need the Elephant install tools, since I can make my own if needed, and there doesn't seem to be any way to buy the Elephant rubber bushings without the tools. |
| mepstein |
May 8 2017, 10:20 AM
Many people have said the URO's squeak - a lot. Use at your own risk.
I think 914rubber might be coming out with a set that mimickes oem. I hope so! |
| BillC |
May 8 2017, 05:30 PM
Many people have said the URO's squeak - a lot. Use at your own risk. I think 914rubber might be coming out with a set that mimickes oem. I hope so! Are you sure the rubber bushings squeak? I've heard of urethane bushings squeaking, but not properly-installed rubber ones. I searched this site, and googled the internet, but didn't turn up any complaints about squeaking from the rubber bushings. Also, I called 914Rubber, and while they might be working on the front bushings, they won't be available anytime soon. |
| raynekat |
May 8 2017, 06:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Elephant Racing rubber bushings are great and worth the money. I wouldn't even try URO for such an important application as that.
| HalfMoon |
May 9 2017, 01:44 PM
Figured out my wobble. PO had failed to use a lock plate on the driver side (and I had never noticed it). Ball joint was hand tight.
New ones from the bird on the way. Jeez, will I ever stop finding the jack wagon stuff my PO did? |
| Mikey914 |
May 9 2017, 08:48 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Many people have said the URO's squeak - a lot. Use at your own risk. I think 914rubber might be coming out with a set that mimickes oem. I hope so! No, we will make the better. (IMG:style_emoticons/default/biggrin.gif) Suck it URO (IMG:style_emoticons/default/stromberg.gif) |
| porschetub |
May 9 2017, 10:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,181 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes I can imagine the URO stuff is (IMG:style_emoticons/default/stromberg.gif) ,remember the first part from them I bought off Pelican,voltage reg for my mk2 Golf GTI,failed after a very short time left me with a flat battery on the side of the road....and no I wasn't close to home.
Anyway back to the subject,just done shock inserts,tierod ball joints and new Weltmieister swaybar link bushes,all else checked out fine. End was night and day over what I had,really a big difference,no more bump steer and tramlining,PO said the front inserts were good,I got (IMG:style_emoticons/default/sheeplove.gif) and its not the only thing (IMG:style_emoticons/default/sad.gif) |
| BillC |
May 10 2017, 01:35 PM
Any idea when? I want to re-do my front bushings very soon. |
| Mikey914 |
May 10 2017, 06:49 PM
Tooling is underway right now. We have some testing to do, but will be available in less than 8 weeks.
Mark |
| HalfMoon |
May 22 2017, 04:40 PM
Well replacing the ball joints didn't fix my high speed wobble, so now I'm looking at the tie rods. While they both seem worn (and since the boots are compromised I'll be replacing and upgrading to the 930 turbo tie rods) I don't feel as if that's the causation. Also, the wheel bearings seem ok with no clunking or rotation noise.
I did however detect something on the drivers side of the steering rack. There's some definite movement and even a slight clunking noise. But could this be the reason for a high speed wobble? I have a spare rack from a parts car and when I compare, the spare does NOT have the movement and clunking I detect on the rack that's on the car. Check the vid attached to see what I'm talking about. Anyone have actual not theoretical experience on this? https://youtu.be/dKwYfT0yTnA |
Lo-Fi Version | Time is now: 4th October 2026 - 05:46 AM |
