| mepstein |
May 22 2017, 06:10 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Check the wheel balance.
| Eric_Shea |
May 23 2017, 05:04 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
| 914_teener |
May 23 2017, 05:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes.....I have actual experience.
Looking at your video looks like the spindle end of the tie rod. Most likely the "yoke" end of the the tie rod rubber looks like petrified bakelite or some such mess, causing the "wobble". Be careful when driving out any part of the suspension connected to the rack.....you can damage it. When I put the TT rods on my car I cut the tie rods ends off the spindle just for that reason. Good Luck. |
| 914_teener |
May 23 2017, 05:47 PM
One other thing....check the steering shaft coupler condition.....you will have to pull the tank....and make sure the unijoints of the steering shaft are tight and not binding.
| HalfMoon |
May 24 2017, 05:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Yes.....I have actual experience. Looking at your video looks like the spindle end of the tie rod. Most likely the "yoke" end of the the tie rod rubber looks like petrified bakelite or some such mess, causing the "wobble". Be careful when driving out any part of the suspension connected to the rack.....you can damage it. When I put the TT rods on my car I cut the tie rods ends off the spindle just for that reason. Good Luck. Hmmm. Perhaps. We will know soon enough as the bird is sending me some TT rods and a bump steer. The rubber grommets didn't look or feel all that bad but I imagine they have long ago lost their ability to behave the way they were originally intended.... |
| HalfMoon |
| HalfMoon |
May 24 2017, 05:03 PM
Well I managed to get the stock rack out today and when I (carefully) placed the rack in a vice to try and replicate the symptom noted in the video, I wasn't able too.
Now I'm perplexed. As an aside, the replacement (spare) rack I have I've just discovered is a 7820900166 from a 911. Pretty sure this will work ok but thought I'd ask if anyone has experience with swapping out to this 911 rack and if it's upgrade or if it's going to be totally unworkable or what? I'm no longer convinced the stock rack was/is the culprit for the high speed wobble. Certainly won't hurt to be adding the turbo tie rods, but I'm not thinking that will be resolving the problem. One can hope though... |
| Mendivil26 |
May 7 2019, 06:33 AM
Newbie ![]() Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Hello,
Did you end up figuring out what the wobble was? I have the same issue and have been thinking on refreshing my whole front suspension, but not sure where to start. |
| HalfMoon |
May 7 2019, 08:18 AM
| rhodyguy |
May 7 2019, 08:31 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Lowering your car? Bumpsteer kit. 'Shorting' the process will bite you come alignment time. Do all you can afford the first time rather than piecemeal.
| Larmo63 |
May 7 2019, 08:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I haven't heard of anyone dissatisfied with the Elephant rubber control arm bushings. Turbo tie rods make a big difference too.
I'd suggest doing everything a the same time and know that it is completely refreshed. Only buy quality components for your front end. Lemfoerder ball joints, quality TT rods, etc. Don't scrimp here, you'll be rewarded with a great handling car. |
Lo-Fi Version | Time is now: 4th October 2026 - 06:30 AM |
