Group Buy: rear fog light harness |
ConeDodger |
May 7 2017, 05:05 PM
Apex killer! Group: Members Posts: 23,553 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Ok, I've reached out to our own harness expert to see what he would need as far as a group buy to get a reproduction of the original harness done. The harness for these is pretty involved and goes all the way from the lamp to the switch so it isn't a super cheap thing.
We need 20 sets to make this happen and you can probably get Jeff to give you a deal on one of the other types of harnesses he makes or at least throw it in the same box and save some shipping. So, we need at least 20 sets to get the $206 per harness price. Who's in? (IMG:style_emoticons/default/piratenanner.gif) Besides sounding off here, you need to contact Jeff Bowlsby via (IMG:http://www.914world.com/bbs2/style_images/L11E/p_email.gif) with this information - quantity, name, email, and physical address (so he can quote shipping) he will get back to you with total cost. Oh, and Niklas, international shipping is not a problem. |
McMark |
May 8 2017, 05:46 AM
Changed Jeff raw email so spam-bots don't pick it up. (IMG:style_emoticons/default/wink.gif)
And (IMG:style_emoticons/default/icon_bump.gif) |
Jett |
May 8 2017, 08:14 AM
Senior Member Group: Members Posts: 1,630 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Signed up for two.
ConeDodger |
May 8 2017, 08:56 AM
Changed Jeff raw email so spam-bots don't pick it up. (IMG:style_emoticons/default/wink.gif) And (IMG:style_emoticons/default/icon_bump.gif) You're so kind. I completely forgot about that! (IMG:style_emoticons/default/sad.gif) |
maf914 |
May 8 2017, 10:08 AM
Is the rear fog-light controlled by the front fog-light switch? Or is a separate rear fog-light switch used?
raynekat |
May 8 2017, 01:50 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Is the rear fog-light controlled by the front fog-light switch? Or is a separate rear fog-light switch used? Can do either....depends if you want the front and rear fogs to operate independently or not. I have opted to add a 2nd switch for maximum control. BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. |
Norskpole |
May 8 2017, 04:24 PM
Member Group: Members Posts: 60 Joined: 18-April 10 From: Oceanside, CA Member No.: 11,628 Region Association: Southern California |
I'm in for 2 sets
JeffBowlsby |
May 8 2017, 06:00 PM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. Looks simple alright, but don't be deceived about how easy it is to push a single wire through about 20 feet of small diameter heat shrink. And the white/green stripe wire is special order only available in 1000ft quantities... |
TJB/914 |
May 8 2017, 06:43 PM
Mid-Engn. Group: Members Posts: 4,325 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. Looks simple alright, but don't be deceived about how easy it is to push a single wire through about 20 feet of small diameter heat shrink. And the white/green stripe wire is special order only available in 1000ft quantities... Hi Jeff, I agree it's not simple threading small wires through 20' of a small dia. heat shrink. (IMG:style_emoticons/default/headbang.gif) Wondering?? How is the harness routed from the Fog Light to the dash switch?? What route & through what opening in the engine fire wall into the cabin?? A general routing would be appreciated, Fog Light to dash. (IMG:style_emoticons/default/idea.gif) The reason for asking, I haven't hooked mine up yet. (IMG:style_emoticons/default/w00t.gif) Tom |
ConeDodger |
May 8 2017, 11:02 PM
I guess you actually aren't one of the cool kids are you TBlizz??? (IMG:style_emoticons/default/evilgrin.gif)
You was posing! (IMG:style_emoticons/default/blink.gif) |
JeffBowlsby |
May 8 2017, 11:38 PM
Through the center tunnel next to the chassis harness. Up through the snorkel, to the drivers side engine bay, just zip tie it to the chassis harness. Ground point is under the relay board. Pretty intuitive once thought through.
porbmw |
May 9 2017, 12:21 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
jkb944t |
May 9 2017, 05:53 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
BTW: the factory harness which I have in my hand consists of two wires, two sleeves and 3 crimp on connectors. That's it. Very simple. Looks simple alright, but don't be deceived about how easy it is to push a single wire through about 20 feet of small diameter heat shrink. And the white/green stripe wire is special order only available in 1000ft quantities... Wouldn't it be easier to run .03 mig welding wire through the heat shrink sleeve and then hook it to the wire and pull it back through the 20 feet of heat shrink sleeve? Jeff B |
ConeDodger |
May 9 2017, 10:32 AM
Looks like we're 1/4 of the way there. Some might have just contacted Jeff directly and not sounded off here.
(IMG:style_emoticons/default/cheer.gif) Let's get this done guys! |
Norskpole |
May 10 2017, 07:37 AM
Looks like we're 1/4 of the way there. Some might have just contacted Jeff directly and not sounded off here. (IMG:style_emoticons/default/cheer.gif) Let's get this done guys! bump |
ConeDodger |
May 10 2017, 09:47 PM
(IMG:style_emoticons/default/icon_bump.gif) get to it guys! We need 20 to make this fly! (IMG:style_emoticons/default/biggrin.gif)
ConeDodger |
May 13 2017, 10:16 PM
Get your orders in! We need to make this happen ! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
ConeDodger |
May 14 2017, 08:56 AM
It's Mothers Day! You mothers need to order your rear fog light harness! (IMG:style_emoticons/default/cheer.gif)
ConeDodger |
May 15 2017, 05:20 PM
Can't turn it on unless you wire it up! Order up guys! (IMG:style_emoticons/default/biggrin.gif)
ConeDodger |
May 16 2017, 09:34 PM
Harness time! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Lo-Fi Version | Time is now: 20th April 2024 - 07:08 AM |
