9/1973 914-6 conversion full respray Grand Prix White, Selling my car. |
Deraffe |
May 14 2017, 09:20 PM
I'm new here ... Group: Members Posts: 0 Joined: 26-March 17 From: Scottsdale AZ Member No.: 20,959 Region Association: None |
To start with, I built this car for my father using parts from his euro gray market 1971 911s about 15 years ago when I was working at Stuttgart Southwest a local independent Porsche repair shop.
I started with a nice roller 9 of 73 914 and replaced both the battery tray and the outer rear a arm mount after finding some rust issues after removing the battery tray. I used factory sheet metal to replace everything, no janky after market stuff and everything was repaired to look factory otherwise, there was no other body issues. The car was then resprayed Grand Prix White. Quick back ground on the donor car. My father bought a gray market 1971 911s when I was in 7th grade, by the time I was in my mid 20's he was looking into having the engine rebuilt then restoring the body. After a long search he found an engine rebuilder, then shortly after doing the break-in 500 miles and oil change, the door catch on the drivers side b pillar ripped off of the body when he closed the door. This led to discovering further rust issues and the decision to look for a solid roller to swap the parts over for a 914-6 conversion. * Motor...... Full rebuilt 2.4 Euro S 911 motor from my father's Euro 911s. It was rebuilt 1 year prior to starting the project. It was actually completely rebuilt, not just honed and re-ringed like most people do. Stock rebuilt using KS bearings, honed and resized rods, polished crank, reused pistols and liners (all were in spec and the liners were still round), blue printed oil pump, all the oil galleys were cleaned out and the oil squirters were verified working and Carrara timing chain tensioners were added. The heads were rebuilt with NEW guides and seals, re ground valves with a 3 angle valve job and NEW springs, NEW keepers/retainers, a very slight fly cut to make sure they sealed. (the compression was raised very slightly from this over stock. All of the other valve train parts were checked, found to be with in spec and reused. Around 5 k miles on the motor since rebuild. It is running mechanical injection with a new transfer pump and rebuilt mechanical pump. The linkage is tight as well as no leaks at the throttle shafts and topped off with K&N open filters (i still have the stock air cleaner assembly if you want that.), headers and a Borscht muffler. Tranaxle...... Completely rebuilt 901 side shift with NEW shift forks and syncro rings and magna fluxed stock gears, around 2500-3000 miles on the trans since rebuild. Trans shifts perfectly and I have done 2 fluid changes the first 2 break-in changes using regular gear oil and the last using Mobil1 synthetic gear oil. Brakes and suspension........... I used the 911 front suspension from the donor car including the Koni front shocks and sway-a-way front torsion bars (i don't remember what size they were though), rebuilt aluminium 4 piston calipers and corresponding rotors, 911 front sway bar, rear brakes are stock 914 with 914-6 hubs and redrilled rotors, weltmeister springs and KYB shocks. The car is slightly lowered all the way around. I also used a W123 Mercedes master cylinder with a bracket welded onto the beam to take up the gap and keep the firewall from flexing under braking. The W123 master cyl is a larger bore then the 911 upgrade and a better brake feel. The car also has a space saver 5 lug spare. Body.......... Stock sheet metal with the rear fenders pulled slightly to fit the wheels. 16x6 front and 16x8 rear Carrera 2 staggered wheels and Kumho tires. All the rubber is in good shape and the top and door seals were replaced after the car was sprayed Grand Prix White. The bumpers are black and the rubber is in nice shape. The engine deck lid is a copy of a 914-6 GT with the center cut out and engine grill mesh welded in and painted body colour. I did this to get maximum cooli,g air into the 2.4lt 190hp Euro S motors and to help control the temps here in the hot AZ summers. All the body emblems have been shaved including the hood emblem and the B pillars have had the vinyl removed and were painted body colour with the lower chrome trim removed and holes filled. The car currently has Hella Euro front turn signal lenses. I had amber Hella front turn lenses on the car, but after I took the car to a body shop to get a few small chips and a door ding fixed, the over zealous body tech cranked down the screws and broke the plastic. I will include them with the same though. It has regular US spec tail lights and side markets. The head lights are H-4 housings with high output bulbs (i don't remember the wattage). The rocker covers are also painted black. Interior........... The interior is stock with the exception of a MOMO Monte Carlo 350mm steering wheel, MOMO 4 point belt with Weltmeister harness bar (drivers side only) and a MOMO shift knob. It has the appearance interior with the center console and gauges, the top gauge has been replaced with a VDO oil pressure gauge, but I still have the clock and will include it with the same. The gauges are from a 911 to match the engine with the correct tact and speedo. The cluster backing has been painted body colour. There is an aftermarket Alpine removable face deck, but it is getting old and I would replace it with something newer that works with an mp3 player or phone. There is roughly 5-6K miles on the car since it was finished as it was a nice weather play car. Asking $30k firm. Feel free to shoot me an offer and I can provide more pics if needed. The worst I can say is a polite no thank you. The way to contact me is by my cell which I will give out to serious buyers. |
billh1963 |
May 16 2017, 08:22 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Deraffe: The engine ($$$$$$$$$) is what's driving the interest. Do some research (IMG:style_emoticons/default/smile.gif)
campbellcj |
May 16 2017, 06:28 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Deraffe: The engine ($$$$$$$$$) is what's driving the interest. Do some research (IMG:style_emoticons/default/smile.gif) Yup that's what I was hinting at as well. List that engine on the early911sregistry or pelicanparts 911 board and see what happens. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 06:30 AM |
