Blinkers... Flashers, just stopped working |
malcolm2 |
May 15 2017, 04:11 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I noticed it at lunch today. The blinker indicator in the dash would flash 4 or 5 times, then stop.
Coming home I tried the e-flashers. Same deal. Maybe 7 flashes then OUT. Try the left side, 2 flashes, right side 4 flashes.... then OUT. Now I get no flashes at all. Got a few honey do things to knockout this afternoon then I will start poking around. Figured I'd start with the fuse, then relay. Seeing how it is the flasher and the blinker, I will rule out the lever and such in the column. How do you test a relay anyway? Chime in with some thoughts. Thanks, Clark |
Valy |
May 16 2017, 07:54 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
C will only flash if there is load (bulb connected) on 49A.
Do your indicators stop blinking when the dash light stops blinking? If not, check the grounding of the indicator bulbs. BTW, you don't have LEDs , do you? |
Lo-Fi Version | Time is now: 20th April 2024 - 05:45 AM |
