Blinkers... Flashers, just stopped working |
malcolm2 |
May 15 2017, 04:11 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I noticed it at lunch today. The blinker indicator in the dash would flash 4 or 5 times, then stop.
Coming home I tried the e-flashers. Same deal. Maybe 7 flashes then OUT. Try the left side, 2 flashes, right side 4 flashes.... then OUT. Now I get no flashes at all. Got a few honey do things to knockout this afternoon then I will start poking around. Figured I'd start with the fuse, then relay. Seeing how it is the flasher and the blinker, I will rule out the lever and such in the column. How do you test a relay anyway? Chime in with some thoughts. Thanks, Clark |
Valy |
May 16 2017, 07:54 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
C will only flash if there is load (bulb connected) on 49A.
Do your indicators stop blinking when the dash light stops blinking? If not, check the grounding of the indicator bulbs. BTW, you don't have LEDs , do you? |
malcolm2 |
May 16 2017, 08:48 PM
C will only flash if there is load (bulb connected) on 49A. Do your indicators stop blinking when the dash light stops blinking? If not, check the grounding of the indicator bulbs. BTW, you don't have LEDs , do you? After i re-connected the relay everything started working properly. No LEDs. So i guess you are saying if the big bulbs are out, the dash indicator won't work either? That was my issue on the bench. Would have needed to wire up 2 bulbs. But I don't follow the readings when the relay was mounted and the car was running. C and 49a showed voltage. Inquiring minds want to know. |
Valy |
May 17 2017, 12:11 AM
C will only flash if there is load (bulb connected) on 49A. Do your indicators stop blinking when the dash light stops blinking? If not, check the grounding of the indicator bulbs. BTW, you don't have LEDs , do you? After i re-connected the relay everything started working properly. No LEDs. So i guess you are saying if the big bulbs are out, the dash indicator won't work either? That was my issue on the bench. Would have needed to wire up 2 bulbs. But I don't follow the readings when the relay was mounted and the car was running. C and 49a showed voltage. Inquiring minds want to know. When one bulb burns, the blinking will be faster. When both burn, the dash light will not blink. It seems you had a bad contract that caused a voltage drop at the relay. It solved itself by removing and reinstating the relay. Clean the contacts. |
Lo-Fi Version | Time is now: 26th April 2024 - 09:29 PM |
