Blinkers... Flashers, just stopped working |
malcolm2 |
May 15 2017, 04:11 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I noticed it at lunch today. The blinker indicator in the dash would flash 4 or 5 times, then stop.
Coming home I tried the e-flashers. Same deal. Maybe 7 flashes then OUT. Try the left side, 2 flashes, right side 4 flashes.... then OUT. Now I get no flashes at all. Got a few honey do things to knockout this afternoon then I will start poking around. Figured I'd start with the fuse, then relay. Seeing how it is the flasher and the blinker, I will rule out the lever and such in the column. How do you test a relay anyway? Chime in with some thoughts. Thanks, Clark |
Spoke |
May 16 2017, 12:23 PM
Jerry Group: Members Posts: 6,973 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Yes, with one bulb load the relay should flash.
malcolm2 |
May 16 2017, 01:02 PM
Yes, with one bulb load the relay should flash. Good News, Bad News, I guess... the relay worked on the bench. Using 49a I got a bulb to flash and of course the relay clicked. I know you said not to worry about the C terminal, but for giggles, I put the bulb connection on the C term and nothing happened. is that expected? Or maybe half of my relay is bad? (IMG:style_emoticons/default/blink.gif) |
Spoke |
May 17 2017, 05:27 AM
Yes, with one bulb load the relay should flash. Good News, Bad News, I guess... the relay worked on the bench. Using 49a I got a bulb to flash and of course the relay clicked. I know you said not to worry about the C terminal, but for giggles, I put the bulb connection on the C term and nothing happened. is that expected? Or maybe half of my relay is bad? (IMG:style_emoticons/default/blink.gif) OK, sounds like your flasher is working. If it flashes with one bulb connected it is functional. About connecting the bulb to C (I assume from C to ground), in your car there is always a bulb connected from C to ground ('74-'76 914 only). It is the bulb in the tach. This is why I said don't worry about the C terminal until you test the flasher functionality. Now that you've proved the flasher works, to test C, connect power to 49, ground to 31, a bulb to 49a to ground, and a small marker bulb between C and ground. C should light the marker bulb when the flasher is flashing. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:25 AM |
