Clutch cable tube in tunnel, should there be any movement ? |
porschetub |
May 16 2017, 03:44 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have some movement @ the front securing bracket ,is that normal or is it starting to break ?
Reason I ask is I have had to adjust my new clutch several times,maybe my new cable is continually stretching as I have set to correct freeplay on every occasion. Had my gearbox out to replace input shaft seal and besides minor oil contamination (cleaned up ) it was well....a new clutch. TIA |
Rand |
May 16 2017, 03:53 PM
Sounds like it's more than starting. (IMG:style_emoticons/default/sad.gif)
I'd reinforce in the tunnel and at the firewall in the engine compartment, and the sooner the better. Even if it was something else, this is an upgrade we'll all need at some point. |
burton73 |
May 16 2017, 04:40 PM
burton73 Group: Members Posts: 3,457 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
The front should not move at all. It is just a small amount weld attaching the tube to the body up front.
This is a problem on 914s and there are lots of write-ups on it. It comes lose at every place it is welded to the car. Not so easy to fix completely without having the metal on the bottom opened up. Lots of creative temporary fixes but you need to look up old postings and see the ways people have done this over the years. You will see u bolts jobs, welding part of it. Remember that your gas runs through the center tube as well as wiring and more. When you see some pictures you will have a much better idea of what you have to do. Bob B (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
76-914 |
May 16 2017, 05:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,454 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif)
Rand |
May 16 2017, 05:48 PM
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif) You could. Don't you think that welding up something makes sense at this point? |
porschetub |
May 16 2017, 06:49 PM
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif) You could. Don't you think that welding up something makes sense at this point? Thanks,so movement equals bad news,think it maybe starting to break @ the point towards the centre as opposed to the whole thing breaking at the side spot welds on the left side of the tunnel ...need more time in there ,will report back,think I will cut inspection hole on the top as I need to fix up where some clown had done this !!!!! PO did say this was done when he got the car WAY back so I will tidy this up @ the same time. Rand found all other attachment points to be ok so maybe I have it in time (IMG:style_emoticons/default/confused24.gif) |
porschetub |
May 18 2017, 04:40 PM
Researched and found the spot welds holding the bracket are 3'' forward of the shifter is this correct before I start (IMG:style_emoticons/default/sawzall-smiley.gif) ?or this this case grinder.
burton73 |
May 18 2017, 06:29 PM
Do the research on old postings. I find that it is easer to look up questions on Google asking something like “clutch tube lose on 914 Porsche”
I find it is much easer that using the search engine in on our site. Look at all the pictures and people show their different fixes for this problem. To fix it for the longer run as I said you have to open it up but you may use a U bolt and nuts for a somewhat long fix. See what that looks like. With that fix there is no welding just drilling and bolting. My 6 was fixed that way when I got it and I have no idea if it worked right or for how long. I fixed it right when I went in for the full restoration of her. You have to be very careful in any drilling or cutting because of possible damage or fire. It is hard to see clearly in your picture, as it is too dark. Bob B |
burton73 |
May 18 2017, 06:32 PM
Rand |
May 18 2017, 08:03 PM
porschetub |
May 20 2017, 05:19 PM
Thanks Bob and rand,picked up on Spokes repair was just confirming before I cut,I can't see a thing up there with a torch ??,the link provided has given me more good info (IMG:style_emoticons/default/beer.gif) .
No I don't plan on using u-bolt that's a bit hillbilly to me,I have started to make I clamp bracket I will weld to the base of the tunnel,hopefully fixed to the original one. All good on the proximity of the fuel lines,mine is metal towards the rear going to new plastic line @ that point next to the shifter. Not too concerned as I would like to paint the bottom of the tunnel so now is my change and I may do the rear bracket too. Thanks all for comments. |
Lo-Fi Version | Time is now: 28th March 2024 - 09:53 AM |
