Clutch cable tube in tunnel, should there be any movement ? |
porschetub |
May 16 2017, 03:44 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have some movement @ the front securing bracket ,is that normal or is it starting to break ?
Reason I ask is I have had to adjust my new clutch several times,maybe my new cable is continually stretching as I have set to correct freeplay on every occasion. Had my gearbox out to replace input shaft seal and besides minor oil contamination (cleaned up ) it was well....a new clutch. TIA |
76-914 |
May 16 2017, 05:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 09:49 AM |
