Clutch cable tube in tunnel, should there be any movement ? |
porschetub |
May 16 2017, 03:44 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have some movement @ the front securing bracket ,is that normal or is it starting to break ?
Reason I ask is I have had to adjust my new clutch several times,maybe my new cable is continually stretching as I have set to correct freeplay on every occasion. Had my gearbox out to replace input shaft seal and besides minor oil contamination (cleaned up ) it was well....a new clutch. TIA |
76-914 |
May 16 2017, 05:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif)
Rand |
May 16 2017, 05:48 PM
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif) You could. Don't you think that welding up something makes sense at this point? |
porschetub |
May 16 2017, 06:49 PM
You can remove the bolts from the shifter base, turn the base 90 degrees and with a flashlight see that front weld joint to see if it broke loose. (IMG:style_emoticons/default/beerchug.gif) You could. Don't you think that welding up something makes sense at this point? Thanks,so movement equals bad news,think it maybe starting to break @ the point towards the centre as opposed to the whole thing breaking at the side spot welds on the left side of the tunnel ...need more time in there ,will report back,think I will cut inspection hole on the top as I need to fix up where some clown had done this !!!!! PO did say this was done when he got the car WAY back so I will tidy this up @ the same time. Rand found all other attachment points to be ok so maybe I have it in time (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 04:50 AM |
