Clutch cable tube in tunnel, should there be any movement ? |
porschetub |
May 16 2017, 03:44 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have some movement @ the front securing bracket ,is that normal or is it starting to break ?
Reason I ask is I have had to adjust my new clutch several times,maybe my new cable is continually stretching as I have set to correct freeplay on every occasion. Had my gearbox out to replace input shaft seal and besides minor oil contamination (cleaned up ) it was well....a new clutch. TIA |
porschetub |
May 18 2017, 04:40 PM
Researched and found the spot welds holding the bracket are 3'' forward of the shifter is this correct before I start (IMG:style_emoticons/default/sawzall-smiley.gif) ?or this this case grinder.
Lo-Fi Version | Time is now: 11th May 2024 - 12:38 PM |
