F/S 3.0 inch spacing Brembo calipers, Restored by PMB |
Harpo |
May 17 2017, 06:19 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
toolguy |
May 17 2017, 08:50 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
bleeder goes on the top. .
McMark |
May 17 2017, 10:51 AM
Unless you flip the strut for ultimate lowering. (IMG:style_emoticons/default/happy11.gif)
Harpo |
May 18 2017, 11:08 AM
Thanks guys for the bump
Harpo |
May 18 2017, 06:13 PM
Justinp71 |
May 19 2017, 11:40 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Are these early 911 calipers rebuilt? If not, what size piston are they?
Thanks |
amfab |
May 19 2017, 12:17 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Are these early 911 calipers rebuilt? If not, what size piston are they? Thanks I think these are the aluminum brembos—alfa calipers see: http://www.914world.com/bbs2/index.php?showtopic=105728 |
Harpo |
May 20 2017, 04:17 AM
Yes, these early Brembo calipers are from an alpha romeo
Harpo |
May 21 2017, 02:52 PM
Harpo |
May 21 2017, 03:07 PM
I borrowed this from PMB performance
Here's the low-down: These Brembos have a 3" bolt spacing and the exact same offset as the M-Caliper. This means they'll simply bolt right on. When I say bolt on I mean... all the way. They even fit with the standard dust shields. The fluid inlet is aimed right up at the tab on the strut for a direct in. They have the same 48mm piston as the M-Caliper, S-Caliper and the later A-Caliper. What's cool about this is, they are the later "cup" type piston with no knock-back mechanism to deal with. The cup design offers better cooling with much more surface area than the standard M and S-Caliper pistons. Also nice is the fact that this won't throw off your fluid dynamics with your current Master Cylinder. Again, Bolt on! The pad size is much larger than the M-Caliper pad. They are the same width as the A and S-Caliper pads but not as tall... (only slightly, like 2mm or so). If anyone is familiar with the BMW 320i pad size, these are the same. Another nicety, as I mentioned that these add up in all areas as a true bolt-on upgrade is; with this basic pad size (which has been proven with the S-Caliper and A-Caliper) there is no over stress of the standard 20mm rotor which obviously lived on all 911's through 1983. They weigh in a full 4lbs lighter than the M-Caliper so there goes a good chunk of un-sprung weight (yes, they're aluminum!). Did I say "Bolt on upgrade!"? |
Harpo |
May 22 2017, 10:09 AM
Sale pending
Lo-Fi Version | Time is now: 10th May 2024 - 09:30 PM |
