WTB: caliper bolt, I need to replace one |
slotty008 |
May 18 2017, 12:02 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Now that we are finally back online , I have an urgent question. I just finished repairing my rear brake calipers. The pistons were stuck so I carefully took hem out, cleaned everything up , changed the seals and the dustcaps and put them back together again.
Much easier than I thought it would be , also thanks to the excellent youtube video of PMB Performance. Since I live in Belgium it would have been too expensive to send them to PMB; The import duties when receiving it back are horrible. But there was only one big problem. One of the bolts that keep the calipers together had broken off inside the caliper. ( by the PO) I managed to get the broken piece out with a left tap (wiggling very carefully) took me half an hour to get it out. So far , so good but I can't find a replacement bolt anywhere here in Europe. Even Porsche doesn't have them. So if anyone could tell me where to find them (it's the smaller one of the two) I would be eternally thankful. |
Valy |
May 18 2017, 12:09 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Now that we are finally back online , I have an urgent question. I just finished repairing my rear brake calipers. The pistons were stuck so I carefully took hem out, cleaned everything up , changed the seals and the dustcaps and put them back together again. Much easier than I thought it would be , also thanks to the excellent youtube video of PMB Performance. Since I live in Belgium it would have been too expensive to send them to PMB; The import duties when receiving it back are horrible. But there was only one big problem. One of the bolts that keep the calipers together had broken off inside the caliper. ( by the PO) I managed to get the broken piece out with a left tap (wiggling very carefully) took me half an hour to get it out. So far , so good but I can't find a replacement bolt anywhere here in Europe. Even Porsche doesn't have them. So if anyone could tell me where to find them (it's the smaller one of the two) I would be eternally thankful. Yes, those 7mm bolts are NLA. I have some but not sure what you need as different years had different ones. Is it star or hexagon head? What is the length? |
slotty008 |
May 18 2017, 12:17 PM
Now that we are finally back online , I have an urgent question. I just finished repairing my rear brake calipers. The pistons were stuck so I carefully took hem out, cleaned everything up , changed the seals and the dustcaps and put them back together again. Much easier than I thought it would be , also thanks to the excellent youtube video of PMB Performance. Since I live in Belgium it would have been too expensive to send them to PMB; The import duties when receiving it back are horrible. But there was only one big problem. One of the bolts that keep the calipers together had broken off inside the caliper. ( by the PO) I managed to get the broken piece out with a left tap (wiggling very carefully) took me half an hour to get it out. So far , so good but I can't find a replacement bolt anywhere here in Europe. Even Porsche doesn't have them. So if anyone could tell me where to find them (it's the smaller one of the two) I would be eternally thankful. They are hexagon and 4,5 cm( that's 1,77 inch without the head) Yes, those 7mm bolts are NLA. I have some but not sure what you need as different years had different ones. Is it star or hexagon head? What is the length? |
Lo-Fi Version | Time is now: 17th May 2024 - 09:26 PM |
