Valve guide position 1.7 liter heads, Cylinder head work |
pgollender |
May 19 2017, 08:30 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
After hot tanking I noticed different lengths on my exhaust valve guides. Between the four exhaust guides ( two heads) the length of the top of the guide out of the head varied by 2 mm. Is this a problem or just sloppy work from P.O. ? Does it matter ? |
Mark Henry |
May 19 2017, 07:04 PM
They're driven in, check the seat side I bet they look like they're extra long.
Even the left hand exhaust guide looks like it's sunk in too far, could be just the angle. Cause is likely they were loose and should have had OS guides. Bad valve float can drive them in as well. Surprised the boss isn't cracked. They must be cored and driven out from the camber side, then see if they are salvageable. Yes poor machine work and yes it does matter. |
Lo-Fi Version | Time is now: 24th May 2024 - 04:45 PM |
