How do you line this up ? |
dgraves |
May 19 2017, 07:32 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I'm installing the metal rails for my rubber trim that runs up the side of my Targa roll bar. This is the trim that the back of the door window seals against. See photo.
The rails have holes that allow some play side to side. In order to eliminate multiple tries of lining this up properly, does anyone have some guidance? The top corner needs to line up with the rubber corner of the roof seal against the top of the window. This feels like it's going to be a lot of trial and error to install the metal strip, struggle with the rubber trim, and then find out the window doesn't seal properly. Thank you. |
Lo-Fi Version | Time is now: 30th May 2024 - 12:24 AM |
