putting in my cluster gauge questions?, 3.2 pressure gauge |
buck toenges |
May 10 2005, 08:27 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I screwed up and didn't mark my wires correctly. I am putting in a 3 gauge cluster gauge and am having problems getting my pressure gauge working. Just to make sure... the "+" means power right? the "G" means ground right? and the funny squiggly thingy is where the sender wire goes right? Now how do I figure out which sending wire is from my pressure sensor? I am using the stock 3.2 engine harness with a "adapter" harness going to my stock '71 harness. Is there a way I can find the pressure sender wire up in the dash so I can hook it up to the gauge? I had it before but I can't locate it now. Can I get some sort of tester on the wire to see if it the right one? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
markb |
May 10 2005, 11:33 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Just a guess, but I think the G is for gauge.
Lo-Fi Version | Time is now: 16th May 2024 - 01:33 AM |
