25Amp Battery Fuse Melted |
bandjoey |
May 19 2017, 08:06 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
About a year ago a member here sold a battery fuse kit (Spoke?) Never thought I'd use it but it looked cool.
Started the teener tonight and after a minuted it went Dead Instantly! Knew it was electrical and since I'd recently installed a tach, decided to check the wires. Looked OK. and the dash fused were ok too. Checked the battery fused and found a blown 25 amp fuse. When I think of what might have melted without that fuse................... (IMG:style_emoticons/default/headbang.gif) As soon as the butterfly horn was off, I see a cut horn wire. The DAPO installed this and I have been to lazy to wire it right. Pulled off the horn wire, installed a new fuse, and took her for a spin! With Tim's new LED dash lights, I love driving after dark. So,,,fuse the battery and let Tim do your dash. Attached image(s) |
Spoke |
May 20 2017, 06:53 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
GeorgeRud |
May 20 2017, 07:09 AM
Porsche seems to have a long history of questionable electrical items. My '84 Carrera Targa needed to have 5 additional wires fused as the factory didn't have any (though they did eventually add some to later models).
A fuse or circuit breaker in the circuits fed off the battery would be a nice added level of protection for the wiring. |
76-914 |
May 20 2017, 08:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Tom made those. I've got one on my '76. Damned good idea to have one. Many folks don't know that they have unfused HOT wires running up the tunnel. Glad yours saved your butt. I haven't needed mine yet but it is cheap insurance. (IMG:style_emoticons/default/beerchug.gif)
michael7810 |
May 20 2017, 12:04 PM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Tom made those. I've got one on my '76. Damned good idea to have one. Many folks don't know that they have unfused HOT wires running up the tunnel. Glad yours saved your butt. I haven't needed mine yet but it is cheap insurance. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) I have one on my car and once fried one of the fuses when I hooked the yellow starter wire to the wrong connector. Very happy I didn't have a melted wire and ignition switch. Everyone should fuse all the wires on the battery except the large cable that runs to the starter. |
AZBanks |
May 20 2017, 01:05 PM
Senior Member Group: Members Posts: 1,051 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Does Tom have a thread in the member-vendor section for this?
aharder |
May 20 2017, 02:20 PM
Advanced Member Group: Members Posts: 4,365 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
cary |
May 20 2017, 07:37 PM
We'll be doing an engine panel on Doug's 6 conversion. I'm thinking circuit breakers that you need to reset. So you know you have an issue.
Might get a head start on the design when Matt and I do the new snorkel in his car. I think every car should have one. |
barefoot |
May 22 2017, 04:07 AM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
About a year ago a member here sold a battery fuse kit (Spoke?) Never thought I'd use it but it looked cool. Started the teener tonight and after a minuted it went Dead Instantly! Knew it was electrical and since I'd recently installed a tach, decided to check the wires. Looked OK. and the dash fused were ok too. Checked the battery fused and found a blown 25 amp fuse. When I think of what might have melted without that fuse................... (IMG:style_emoticons/default/headbang.gif) Here's my 1 in 4 out fuse block, think I got it off E-bay or Amazon can't remember now. Will mount where out of direct rain exposure but easy to see fuses. |
76-914 |
May 22 2017, 07:39 AM
Does Tom have a thread in the member-vendor section for this? No. He only offered the kits once. IIRC, the response was small but he might make more if the interest is there. (IMG:style_emoticons/default/beerchug.gif) |
Kansas 914 |
May 22 2017, 08:33 AM
Always keep in mind there are a few unfused circuits on a 914. I too have added a fuse to the battery for unexpected shorts.
Dion |
May 22 2017, 08:40 AM
RN Group: Members Posts: 2,762 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Kansas 914 |
May 22 2017, 12:29 PM
Here's my 1 in 4 out fuse block, think I got it off E-bay or Amazon can't remember now. Will mount where out of direct rain exposure but easy to see fuses. https://www.amazon.com/BQLZR-Illuminated-Tr...r/dp/B01M0KZ8JX |
stinkindiesel |
May 22 2017, 01:07 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I learned this lesson on a very early build 944. Turned the headlights on one night. One popped up, the other didn't. Smoke poured out from under the dash. Entire wiring harness going through the firewall was one big lump of goo. Found out later the headlight motors were unfused. All it took was a stalled motor to lead to a short to lead to China Syndrome.
Gary |
Lo-Fi Version | Time is now: 20th April 2024 - 08:12 AM |
