flywheel seals |
flywheel seals |
JFG |
May 20 2017, 12:28 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Having bought a 914 flywheel for my w code motor i need to buy the correct seals to reassemble that area.
I have the large outer seal but looking on the parts catalogue there is a felt ring and i've also seen a large o ring advertised. Can someone advise about this o ring, i see no place that one would sit and seal. Also the felt ring. Is 111 105 311 the same as 021105311? |
Frankvw |
May 20 2017, 01:12 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Yes...buy the o ring and feltring as well. Both really cheap. You MUST have the O ring. The felt ring is something you could run without if it was not available and the build is waiting. But it is a cheap part so do not skip it to save money (about 1 dollar). The engineers at VW/Porsche did not create the felt ring if not really needed so it has a (small) purpose. It creates a dustbarrier. Good luck !
Lo-Fi Version | Time is now: 17th May 2024 - 03:11 PM |
