914 "Need to Know" items for my son, If and when he inherits my car, someday... |
oakdalecurtis |
May 20 2017, 01:19 AM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I am in no hurry to go, but someday my 35 year old son will inherit my 914. He is good mechanically, but he has never spent time working on the 914 with me, for many life reasons. (He's a corporate jet pilot, always been busy flying). I thought I would write a list of "Need to Know" items to give him a good start with the car when that day comes. Here's my list. Anything else come to mind to consider?
- ALL bolts are metric. - Only two local mechanics know how to fix 914’s properly. Terry at Kruse-Lucas in Modesto and Keith at Eurotrends in Ceres are the ones. Only Terry at Kruse Lucas has the equipment to smog it. - Engine valves should be adjusted professionally every 5000 miles, by Terry or Kieth. - All removed car parts are in a plastic bin in the garage room. - Run the engine on 87 octane gas, do not go by the 91 RON sticker, that’s a European octane rating, different than US octane rating. Higher octane will make engine run hotter and your wallet run thinner. - Use only 20/50 Brad Penn Racing Oil, order online. This oil has higher levels of ZDPP to protect older engines. Use only a Royal Purple 20-253, Mahle OC-28, or Mann W920/17 oil filter, also ordered online. Change oil filter from below, on passenger side of engine block near firewall. PAN PLUG TORQUE IS ONLY 16 ft/lbs, and SUMP PLUG IS ONLY 9.4 ft/lbs. Any more torque will cause BIG damage to engine. I just cleaned out the sump screen, so it’s not necessary to do again for a LONG time. Just change the oil via the pan plug every 3000 miles or once per year. Install a new crush washer (AutoAtlanta has them) on the pan plug, with the washer seam TOWARD the bolt head. NEVER let an oil change shop do the oil change, as they are clueless and will over torque the plug and damage the engine. It’s an easy do it yourself job. Complete oil change instructions are in my personal computer files under Cars/914. - The idle adjust screw is on the back of the throttle body, if you stand on the passenger side of the car and reach around throttle body. Only adjust the idle when the engine is warm. The idle mixture control, done at idle only, is the “white line” knob on the back of the black ECU box on the firewall behind the battery. - Don’t use a K&N air filter, just a standard paper air filter. Oil in the K&N filters is bad for the engine sensors. - If the battery is disconnected and reconnected for maintenence, the radio antenna will not go up until you push the radio power button several dozen times, not sure why. - The rain tray under the engine access lid has been removed so the engine runs cooler, and also to allow installation of the BlazeCut fire suppression system tube. Do not run the car in the rain if you can help it, since the body steel is not galvanized and will rust easliy from any trapped water. - If the rear trunk release solenoid is not working, an emergency trunk release cable is hanging under the center of the rear bumper just above sight line. - Run stock tire size. Low profile tires will make ride quality very harsh, trust me. - Brake pads are in great shape, and should last a long time. - Fuses are under the dash on the drivers left knee area. Fuses are color coded for amperage. Relays are on the relay board just above those fuses, which is accessed by removing the two screws holding the relay board up. I recommend disconnecting the negative cable from the battery before dropping the relay board. - Another relay board is found in the engine compartment under a plastic cover below the theft alarm. There is also one fuse on it controlling most engine functions. The Voltage Regulator is also on this relay board, accessed by carefully removing plastic box cover with snap clip on the bottom edge . |
rick 918-S |
May 20 2017, 03:08 AM
Hey nice rack! -Celette Group: Members Posts: 20,422 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
My experience, kids seldom like the same cars their dads like. Specially if you have to follow your dads list. That said, drive it like you stole it.
orthobiz |
May 20 2017, 07:25 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Looks like a 1976 car from your profile page. That will help in making recommendations...
Paul |
Mikey914 |
May 20 2017, 09:14 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I think the key is to get him driving one. Not yours, but his own. So he has need to spend time working on it with you. He will also appreciate the quirks and things that make the car special. He needs a taste if he's going to get the bug. Both my boys enjoy their 914's. Micheal (the original mikey914) got his taste and when we were in Medford the right opportunity arose and he's back in one (Matt borrowed work WCR this year because his isn't ready).
Taylor is doing a rotisserie restoration with some help from Cary. Hopefully we can get it close by the end of the year. Eventually, the car will make it's way to him and he will truly appreciate the time spent going to events, turning a wrench, and spending time with family. Besides I'd bet he could store it in the hanger. (IMG:style_emoticons/default/biggrin.gif) |
oakdalecurtis |
May 20 2017, 10:04 AM
My experience, kids seldom like the same cars their dads like. Specially if you have to follow your dads list. That said, drive it like you stole it. Actually, he does appreciate and want the car, someday. And unlike me, he follows lists really well, like pre flight checklists. However, that "dad likes" strategy is how I got rid of certain boyfriends my daughter dated long ago. If I acted as if I really liked them after first introductions, she usually tossed them aside before the end of the week! (IMG:style_emoticons/default/piratenanner.gif) |
sb914 |
May 20 2017, 11:14 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Most importantly
May 20 2017, 03:24 PM
oakdalecurtis |
May 20 2017, 03:27 PM
That's odd Dave, why you think they would metric everything but the seat belt bolts? Maybe USA only thing? |
LowBridge |
May 20 2017, 03:58 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
great list... I hope he does not need it for many years to come (IMG:style_emoticons/default/beerchug.gif)
oakdalecurtis |
May 20 2017, 04:13 PM
great list... I hope he does not need it for many years to come (IMG:style_emoticons/default/beerchug.gif) If only it were up to me..... (IMG:style_emoticons/default/blink.gif) |
May 20 2017, 06:08 PM
That's odd Dave, why you think they would metric everything but the seat belt bolts? Maybe USA only thing? My guess is that the belt bolts were required for US import. But that they used the same bolts on all cars because it was easier than keeping track of two different sets of bolts. Evidently the RoW cars all got the inch-sized seatbelt bolts as well. --DD |
May 20 2017, 07:18 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
That's odd Dave, why you think they would metric everything but the seat belt bolts? Maybe USA only thing? My guess is that the belt bolts were required for US import. But that they used the same bolts on all cars because it was easier than keeping track of two different sets of bolts. Evidently the RoW cars all got the inch-sized seatbelt bolts as well. --DD Curious, were there no seatbelts in the cars sold in Europe? Was the spec for larger diameter bolts from the NHSTA? And, most important, were those pesky seat belt retaining brackets then applied on US spec cars, once they got here? Rich |
May 21 2017, 12:34 AM
I believe that the belts and such were the same across all markets.
The hardware is SAE sized. That's really all I know, the rest is speculation. --DD |
EdwardBlume |
May 21 2017, 05:04 AM
and if you get stuck:
www.914world.com (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) |
mbseto |
May 23 2017, 09:29 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
My experience, kids seldom like the same cars their dads like. I'm one of the seldom. Dad's got a talent for picking fun cars... TR6, 240Z, VW GTI (geez, he must have had that car for 20 years), currently driving the model of his first car, TR3. I'd gladly drive any of those. Apropos to the OP, I go help dad out with the TR occasionally and I think your son getting hands on is both the best prep and also the best indication that he has some interest in it. |
WPEngels |
May 23 2017, 09:43 AM
Newbie Group: Members Posts: 18 Joined: 20-November 13 From: Netherlands Member No.: 16,678 Region Association: None |
I believe that the belts and such were the same across all markets. The hardware is SAE sized. That's really all I know, the rest is speculation. --DD Hi, long time ago, working for Volvo, I was another guy wondering about this. Here, on this side of the Atlantic (and Channel), everything is metric, except the seatbelt hardware indeed. That's always SAE and had something to do with the original approval of seatbelts and effort involved ($$$) to get approval to use other - metric - hardware or even other sizes of SAE hardware. |
ljubodraz |
May 23 2017, 11:17 AM
Member Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
"- Run the engine on 87 octane gas, do not go by the 91 RON sticker, that’s a European
octane rating, different than US octane rating. Higher octane will make engine run hotter and your wallet run thinner." Interesting that this is the first time I've heard of this issue of cooler temps. I'll have to give it a try. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 07:46 AM |
