SS exhaust needed, SS Exhaust manifold Drivers side |
North Coast Jim |
May 20 2017, 08:11 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Putting back together the 74 2L after 34 years in a barn has been trying at times. She now runs, stops and looks sweet. What fun.
A persistent exhaust leak has been traced to a broken exhaust down tube for cylinder number 2. The welded bung for stud fastening to the head torn the tube metal around 3 sides of the area. We drilled the cracks at their ends to alleviate any stress concentration areas, cleaned the cracks and rewelded the area. Using an Aerospace certified welder and he is knowledgable with SS. Cracked now outside the weld. Tried pass number 2 and it seems to hold. It's back on the car but ........................ My hopes are not high for this being a long term fix so I'm investigating the purchase of a drivers side SS exhaust manifold. It's again for a 2L. Looking for an excellent replacement piece. |
TheCabinetmaker |
May 20 2017, 08:33 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Are you looking for a ssi heat exchanger, or a ss header down pipe?
North Coast Jim |
May 20 2017, 01:13 PM
grimmel |
May 20 2017, 01:49 PM
grimmel Group: Members Posts: 5 Joined: 29-September 11 From: Sacramento, CA Member No.: 13,623 Region Association: Central California |
Are you looking for a ssi heat exchanger, or a ss header down pipe? Exhaust with heat exchanger. The SS equivalent of the original Zinc plasma repair will work, plus it provides corrosion resistance. Companies who do body restorations have the equipment or know who to go to. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:40 AM |
