Rear Trunk opening, Solenoid not working |
Robnxious |
May 20 2017, 11:43 AM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
When I had my car wrapped the kids who did it did something to the rear trunk release and I am going in there today. So actually I can hear the solenoid triggering but it's not open, and I will fix that when I am in there. I have read the posts on here and have a pretty good idea how to do it, and have the proper tools. Just want to verify with anyone who has gotten into the rear trunk through the engine compartment.
1) I am assuming you go through the holes that are covered by the plastic caps (guessing strut holes), but how does one who is, shall we say "not as svelte" get in there to get the ratchet back there 2) I have also read about drilling a hole beneath the solenoid and triggering the release that way (Which I am thinking about doing, since I need to put the idiot release in since the DAPO didn't but a failsafe on it). Anyone got any suggestions since I want to not only get into it today, but also put my new chrome bumpers and bumper tops on this weekend, and I know I need to get into the trunk to do the rear bumper Thanks in advance |
oakdalecurtis |
May 20 2017, 01:25 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I have a rear reflector lens, so I can not use the original push button. I STRONGLY suggest the you add a small cable attached to the release arm in the trunk and run it through a small hole in the bottom of the trunk. Have the cable end up where it cannot be seen from the back of the car, and put a small pull tip on it, see pictures. I guarantee that at some point the solenoid will stick or the battery is too low and it will not release the trunk lid when you need it most. The cable is a backup that you can always use to open the trunk.
Robnxious |
May 20 2017, 01:32 PM
I have a rear reflector lens, so I can not use the original push button. I STRONGLY suggest the you add a small cable attached to the release arm in the trunk and run it through a small hole in the bottom of the trunk. Have the cable end up where it cannot be seen from the back of the car, and put a small pull tip on it, see pictures. I guarantee that at some point the solenoid will stick or the battery is too low and it will not release the trunk lid when you need it most. The cable is a backup that you can always use to open the trunk. Yeah, I know, one of those things that I meant to do after I bought it in November, but since it always opened for me I didn't stress too badly on it now. What is it they say about best laid plans? Thanks for posting those pics since I wasn't too sure on how it connected into the solenoid. |
Lo-Fi Version | Time is now: 10th May 2024 - 02:18 PM |
