Awww crap!, coupler crumbs |
anderssj |
May 21 2017, 09:47 AM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Took the car out for a little dawn patrol run this AM. The first time I upshift to fourth, it is really in neutral . . . that's odd. A little later, down-shifting to third got me fifth . . . weird, but it now has my attention. OK, time to head back to the barn--don't want to be stranded on the side of the road at 7AM on a SUN morning. Once I had the car back in the garage, I peeled back the boot that covers the shift linkage coupler near the firewall:
coupler crumbs (IMG:style_emoticons/default/dry.gif) I guess I get to try fixing something different. After reading the threads here, it looks like my options are using OEM bushings (with the "oblong holes"), or the after-market ("round-hole") bushings from JWest, brass bushings (not sure if these are still available), or a universal joint (by upgrading the whole linkage using Racer Chris' side-shift kit). Right now I'm leaning towards the JWest side shift bushing kit (which includes the coupler bushings), and replacing all of the other shifter bushings at the same time. On the other hand, the Tangerine Racing spherical firewall bearing for the shift rod looks like it may be a good idea . . . . Your thoughts? Thanks in advance for your insights, BTDTs (IMG:style_emoticons/default/pray.gif) |
anderssj |
May 22 2017, 11:45 AM
Thanks for all the suggestions.
I'll be putting the car up on ramps later and see how everything looks. I think there's already a bronze bushing at the transmission end of the shift linkage. I also have a couple of new cone screws (somewhere--will look for those this PM). My current plan is to use the JWest plastic coupler bushings and the Tangerine firewall bushing. As I understand it, if I don't open up the front shift rod clamping bolt (below the gear shift lever), I should be able to put the coupler/rear shift rod back in without a major linkage readjustment. Thanks again for the help! (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 09:58 PM |
