Awww crap!, coupler crumbs |
anderssj |
May 21 2017, 09:47 AM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Took the car out for a little dawn patrol run this AM. The first time I upshift to fourth, it is really in neutral . . . that's odd. A little later, down-shifting to third got me fifth . . . weird, but it now has my attention. OK, time to head back to the barn--don't want to be stranded on the side of the road at 7AM on a SUN morning. Once I had the car back in the garage, I peeled back the boot that covers the shift linkage coupler near the firewall:
coupler crumbs (IMG:style_emoticons/default/dry.gif) I guess I get to try fixing something different. After reading the threads here, it looks like my options are using OEM bushings (with the "oblong holes"), or the after-market ("round-hole") bushings from JWest, brass bushings (not sure if these are still available), or a universal joint (by upgrading the whole linkage using Racer Chris' side-shift kit). Right now I'm leaning towards the JWest side shift bushing kit (which includes the coupler bushings), and replacing all of the other shifter bushings at the same time. On the other hand, the Tangerine Racing spherical firewall bearing for the shift rod looks like it may be a good idea . . . . Your thoughts? Thanks in advance for your insights, BTDTs (IMG:style_emoticons/default/pray.gif) |
Mikey914 |
May 22 2017, 12:09 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Took the car out for a little dawn patrol run this AM. The first time I upshift to fourth, it is really in neutral . . . that's odd. A little later, down-shifting to third got me fifth . . . weird, but it now has my attention. OK, time to head back to the barn--don't want to be stranded on the side of the road at 7AM on a SUN morning. Once I had the car back in the garage, I peeled back the boot that covers the shift linkage coupler near the firewall: coupler crumbs (IMG:style_emoticons/default/dry.gif) I guess I get to try fixing something different. After reading the threads here, it looks like my options are using OEM bushings (with the "oblong holes"), or the after-market ("round-hole") bushings from JWest, brass bushings (not sure if these are still available), or a universal joint (by upgrading the whole linkage using Racer Chris' side-shift kit). Right now I'm leaning towards the JWest side shift bushing kit (which includes the coupler bushings), and replacing all of the other shifter bushings at the same time. On the other hand, the Tangerine Racing spherical firewall bearing for the shift rod looks like it may be a good idea . . . . Your thoughts? Thanks in advance for your insights, BTDTs (IMG:style_emoticons/default/pray.gif) Actually made a redesigned OEM version that is not so oblong. Fits much better. They are correctly toleranced. Offered up a set for free if you want to try. http://www.914world.com/bbs2/index.php?sho...l=shift+knuckle Attached image(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 09:45 AM |
