Repair rubber bumper screws?, or am I screwed??? |
tadink |
May 21 2017, 01:16 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Having sold a rubber bumper top (that is otherwise in very nice condition) I was in the process of removing it from my chrome bumper.
It is held on by a number of bolts embedded in the rubber - and as luck would have it, the bolts and broke off before the nut would move (having rusted itself securely to the bolt!) so - the question: how can you repair and modify the embedded bolts / plugs so that the rubber bumper top can be affixed to a new chrome bumper?? As the pix show - I have 1 bolt remaining, 4 that have sheared off, and one where the 'plug' in the bumper has disintegrated. The missing plug gives me the most hope, as I'm sure one might be able to remove the other 'plugs' and reconfigure something that would hold the bolt. Thoughts or suggestions? tom |
mb911 |
May 21 2017, 01:46 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Way back when I drilled and tapped and threaded in a stud the molded in washer on the bumper tops
rhcb914 |
May 21 2017, 06:25 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Way back when I drilled and tapped and threaded in a stud the molded in washer on the bumper tops (IMG:style_emoticons/default/agree.gif) If there is enough metal to tap that will work for a temporary fix. Use some lock tight and go easy on the torque. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:43 PM |
