How does one remove the J-tubes? |
doug_b_928 |
May 21 2017, 05:33 PM
I can see the brackets that are spot welded to the longs (the bottom halves of mine have disintegrated along with the bottoms of the longs), but how are the J-tubes held in at the top of the long at the front (where it comes through the long and into the cabin) and at the firewall in the rear (mine appears to have brushed on seam sealer around it)?
doug_b_928 |
May 22 2017, 07:59 AM
I have he outer clamshell off, silencer out, and can see how the brackets are spot welded to the side and top of the long. Are the air tubes welded where the exit (at the upper long for the front one and at the firewall for the rear one? If not, then they should be fairly easy to remove, no?
Lo-Fi Version | Time is now: 20th May 2024 - 07:03 PM |
