Reverse grinding, please confirm the cause |
malcolm2 |
May 21 2017, 06:06 PM
IIRC when reverse grinds, it is probably caused by the clutch cable, right?
Stretching a bit or the nuts loosened up? And of course the dreaded tube.... but lets not go there yet. Have I remembered correctly? |
BillC |
May 22 2017, 07:55 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
If you press the clutch pedal and then quickly shift to reverse, you will normally get a grinding sound. As ejm said, the parts are still rotating at that point, and there's no synchronizer on reverse to slow them down.
A "trick" you can try is to shift to a forward gear first, to stop the rotation, and then shift into reverse. Or, you can press the clutch down and wait 5-10 seconds to shift into reverse (friction will slow the shafts, if you give them time). If, however, you try the shift-into-forward-then-into-reverse trick or try waiting a bit before shifting into reverse and still get the grind, then your clutch may be dragging a little. A dragging clutch will keep the parts from slowing down. The two most common causes of a dragging clutch on a 914 are loose/stretched clutch cable or a loose/broken clutch cable tube. A warped clutch disk is another cause, but not as likely as the previous two possibilities. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:12 PM |
