Stripped cone screw....need remedy.., Allen portion stripped...muscle f'd it.... |
second wind |
May 22 2017, 09:50 AM
Senior Member Group: Members Posts: 850 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Well.....life long ailment of fixing something that is working fine already.....I wanted to make sure my shift rod was rrreeellllyyyy tight.....well, it is now! Can't get cone screw back out. Any ideas? Thanks.
gg |
PanelBilly |
May 22 2017, 09:53 AM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Drill
larryM |
May 22 2017, 10:25 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
N_Jay |
May 22 2017, 10:33 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
See if you can get the easy-out to grab as is, before you drill.
The old hole is probably not as smooth as a drilled hole and may grab better. |
rhodyguy |
May 22 2017, 10:44 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
look for a new used rod with a good coupler. it should be cheap and there are prob a gazillion of them in the LA area. put 914rubber coupler bushings in, source a couple of Jwest coupler screws (they have jam nuts and there is no song and dance to reuse them) and be done with it.
May 22 2017, 11:05 AM
Weld a nut onto the end of the cone screw. The heat should help break whatever bonds are holding the screw in place, and the nut gives you an easy place to put a wrench so you can turn it out.
I would not try the easy-out first; those things are brittle and very very very hard. It is relatively common to break an easy-out, and very difficult to drill the easy-out once that happens. --DD |
Amphicar770 |
May 22 2017, 12:09 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry.
Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 |
second wind |
May 22 2017, 12:11 PM
I have used easy outs and once they break, which is every time, now you really have a mess. Never heard of reverse drill bits? Where can I find them? Thank you.
jeffdon |
May 22 2017, 01:39 PM
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry. Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 Torx bit hs worked for me. (IMG:style_emoticons/default/agree.gif) |
john77 |
May 22 2017, 01:52 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry. Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 Torx bit hs worked for me. (IMG:style_emoticons/default/agree.gif) Same here, for exactly the same problem the OP has. Heated with a torch and then hammered in a torx bit and it came right out. |
6freak |
May 22 2017, 02:36 PM
don't think you can! what would be the purpose of a reverse bit, easy outs twist backwards I do know that good luck (IMG:style_emoticons/default/smile.gif) |
PanelBilly |
May 22 2017, 02:43 PM
arne |
May 22 2017, 02:44 PM
Serial Rescuer of old vehicles... Group: Members Posts: 732 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
don't think you can! what would be the purpose of a reverse bit, easy outs twist backwards I do know that good luck (IMG:style_emoticons/default/smile.gif) Reverse bits are designed just for this purpose. As you drill into it, it tends to loosen the bad part, rather than tighten. Often, drilling with a reverse bit will actually allow the screw in question to back out as you drill. https://www.amazon.com/Neiko-10037A-Titaniu...erse+drill+bits However, I doubt that one would work on a coupler cone screw that might still have the self-locking stuff in the threads. |
porschetub |
May 22 2017, 03:44 PM
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry. Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 Torx bit hs worked for me. (IMG:style_emoticons/default/agree.gif) Same here, for exactly the same problem the OP has. Heated with a torch and then hammered in a torx bit and it came right out. Best answer so far (IMG:style_emoticons/default/beer.gif) |
N_Jay |
May 22 2017, 04:53 PM
Never heard of reverse drill bits? Where can I find them? don't think you can! what would be the purpose of a reverse bit, easy outs twist backwards I do know that good luck (IMG:style_emoticons/default/smile.gif) https://www.amazon.com/Tools-Cobalt-64-Inch...0/dp/B0002NYBJG http://www.autozone.com/cutting-drilling-s...set/390938_0_0/ https://www.harborfreight.com/left-hand-dri...3-pc-61686.html |
Redraptor |
May 22 2017, 05:53 PM
Newbie Group: Members Posts: 36 Joined: 18-October 16 From: Louisville, KY Member No.: 20,501 Region Association: MidAtlantic Region |
Get a screw extractor set. I got mine in the drill section of Lowes or Home Depot. Nowhere near as expensive but not as complete as the Irwin set above.
You drill the bit into the stripped screw by using the reverse function on your drill. When the bit sets in the stripped screwhead it is already going in reverse and SHOULD back the stripped screw out. I havent seen them for smaller screws but I havent looked either. They work like a charm when I have used them. A better option than possibly ruining an old tool, but I love buying new tools anyway. |
May 22 2017, 08:20 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry. Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 Torx bit hs worked for me. (IMG:style_emoticons/default/agree.gif) Same here, for exactly the same problem the OP has. Heated with a torch and then hammered in a torx bit and it came right out. Best answer so far (IMG:style_emoticons/default/beer.gif) Another vote, this is why torx bits were invented, right? |
6freak |
May 23 2017, 07:21 AM
don't think you can! what would be the purpose of a reverse bit, easy outs twist backwards I do know that good luck (IMG:style_emoticons/default/smile.gif) Reverse bits are designed just for this purpose. As you drill into it, it tends to loosen the bad part, rather than tighten. Often, drilling with a reverse bit will actually allow the screw in question to back out as you drill. https://www.amazon.com/Neiko-10037A-Titaniu...erse+drill+bits However, I doubt that one would work on a coupler cone screw that might still have the self-locking stuff in the threads. SOB had no idea ...good to know (IMG:style_emoticons/default/smile.gif) |
mbseto |
May 23 2017, 08:35 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
I've used torx and various extractors and also left handed drill bits. It doesn't really get any easier that a left hand drill bit.
bandjoey |
May 23 2017, 03:12 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
And lots of ph blaster first.
Lo-Fi Version | Time is now: 26th April 2024 - 04:24 AM |
