Stripped cone screw....need remedy.., Allen portion stripped...muscle f'd it.... |
second wind |
May 22 2017, 09:50 AM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Well.....life long ailment of fixing something that is working fine already.....I wanted to make sure my shift rod was rrreeellllyyyy tight.....well, it is now! Can't get cone screw back out. Any ideas? Thanks.
gg |
Dave_Darling |
May 22 2017, 11:05 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Weld a nut onto the end of the cone screw. The heat should help break whatever bonds are holding the screw in place, and the nut gives you an easy place to put a wrench so you can turn it out.
I would not try the easy-out first; those things are brittle and very very very hard. It is relatively common to break an easy-out, and very difficult to drill the easy-out once that happens. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 12:32 AM |
