Windshield wiper parts, Are parts to fix the wipers available? |
skjl47 |
May 24 2017, 01:34 PM
Newbie Group: Members Posts: 21 Joined: 2-June 13 From: Northeast TN Member No.: 15,957 Region Association: None |
Hello; I plan to look at a 914 Saturday with the hope it is worth buying. So far the only problem mentioned by the seller over the phone is that the windshield wipers do not work. He does not know why. My question being are these parts the more common or are they among the more rare. I am thinking of all parts in the wiper assembly and I know this is a broad question area.
Back in the day when I owned a 914 for about 12 years (from 1974 to 86) I had a failure of the wipers. One of the metal rods that was a part of the assembly which moved the wipers snapped. I believe I had to replace the entire assembly. parts were likely easier to come by back then. I guess to be more specific, is this an area for which parts are so rare as to be a real problem? I may have a better idea of the specific part needed after looking at the car this weekend. Thanks |
mepstein |
May 24 2017, 01:41 PM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Used assemblys are still cheap $35-75. But more often it's electrical.
porschetub |
May 24 2017, 04:53 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Used assemblys are still cheap $35-75. But more often it's electrical. (IMG:style_emoticons/default/agree.gif) I would start with the wiper switch ,mine cleaned up ok but it was pretty worn,then it failed again and I fitted a spare ok so far. One problem I had was the electrical plug wire retainer on the end of the switch wasn't assembled properly so the power wire wasn't connecting and simply popped out of the holder,some JB weld sorted that. I remember feeding power direct to the motor to confirm it was ok before I put my fuel tank back in,not sure if you can with it in. Best to knock the seller down on this issue and be prepared to spent some time on it yourself. |
skjl47 |
May 24 2017, 07:43 PM
Used assemblys are still cheap $35-75. But more often it's electrical. (IMG:style_emoticons/default/agree.gif) I would start with the wiper switch ,mine cleaned up ok but it was pretty worn,then it failed again and I fitted a spare ok so far. One problem I had was the electrical plug wire retainer on the end of the switch wasn't assembled properly so the power wire wasn't connecting and simply popped out of the holder,some JB weld sorted that. I remember feeding power direct to the motor to confirm it was ok before I put my fuel tank back in,not sure if you can with it in. Best to knock the seller down on this issue and be prepared to spent some time on it yourself. Hello; Thanks good to know the parts are still available. |
branston |
May 27 2017, 07:11 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
Used assemblys are still cheap $35-75. But more often it's electrical. (IMG:style_emoticons/default/agree.gif) I would start with the wiper switch ,mine cleaned up ok but it was pretty worn,then it failed again and I fitted a spare ok so far. One problem I had was the electrical plug wire retainer on the end of the switch wasn't assembled properly so the power wire wasn't connecting and simply popped out of the holder,some JB weld sorted that. I remember feeding power direct to the motor to confirm it was ok before I put my fuel tank back in,not sure if you can with it in. Best to knock the seller down on this issue and be prepared to spent some time on it yourself. Hello; Thanks good to know the parts are still available. I've just been through this hassle, wipers refused to work and after removing them from the car I discovered wiper shaft seized in the bushing it rotates in - this is common with many VW's too. Tearing it down was a bear as it was solidly seized. Once freed up it worked perfectly. I didn't replace pitted shaft just cleaned it up and greased it well. works just fine. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:29 PM |
