stock fuel injection at very high altitudes questions |
piscean914 |
May 24 2017, 06:49 PM
Member Group: Members Posts: 100 Joined: 6-February 04 From: seattle, wa Member No.: 1,637 |
hey guys - i'm off to the wcr next week - my 914 engine is a bit upgraded, but i still run the stock fuel injection - i also have an adjustable MPS (thanks j bowlsby,) and i will bring a portable O2 reader, if i need to make adjustments - i have run this car up to 6000 feet, with no noticeable differences (but not checking the O2 reader) - the WCR will take place in mammoth lakes, ca, which is base elevation at 7880 feet, and up from there! does the stock fuel injection adjust for altitude? if so, how? any other thoughts? thanks for looking! brad k in seattle
Tom_T |
May 24 2017, 07:02 PM
Brad,
The 2.0 Djet EFI's ECU automatically adjusts for altitude & load, etc. & is why it met smog in all 50 states. No more carb re-jetting! I don't know if your upbuild of the 2L will set off some of the settings, but the Djet is supposed to still be good on the 2056s. Unless you've figured a way to take your 914 up the ski lift, then you won't have to worry about any altitude above Mamouth's 7800-ish base! (IMG:style_emoticons/default/biggrin.gif) I've had my stock 73 2L up to 12,000+/- ft mountain passes before without any issues (back in the day 75-85 132K miles as my DD). Safe Travels! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 16th May 2024 - 11:32 PM |
