Rust repair question (patch in front floor flange and jacking donut area) |
doug_b_928 |
May 25 2017, 07:43 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Now that I've got the chassis straight (see 'Puzzling body twist' thread), I'm beginning rust repair. I've removed the outer clamshell on the passenger long. This thing was rusty more than 33 years ago (because these repairs weren't done during my ownership) and someone had scabbed on patches to hide the rust and add strength. I think the front floor is salvageable and so I carefully removed the scabbed on patches that were on the inside of the cabin and underneath the car where they attached to the floor and long, also where the jacking donut was.
The outlined area in the pic below shows where the metal needs a patch. The flange where the floor gets plug welded to the long can't be perforated with a pic, but it's not looking very good (the silver metal in the pic is remnants of the patch that was scabbed onto it). If I cut a piece of 18 gauge per the lines I've drawn and butt weld it, along with the long repair work etc. I will be doing, will that provide sufficient strength in the area of the jacking donut? Or, do I need to add a second layer somehow to strengthen this patch? |
mb911 |
May 25 2017, 01:55 PM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Now that I've got the chassis straight (see 'Puzzling body twist' thread), I'm beginning rust repair. I've removed the outer clamshell on the passenger long. This thing was rusty more than 33 years ago (because these repairs weren't done during my ownership) and someone had scabbed on patches to hide the rust and add strength. I think the front floor is salvageable and so I carefully removed the scabbed on patches that were on the inside of the cabin and underneath the car where they attached to the floor and long, also where the jacking donut was. The outlined area in the pic below shows where the metal needs a patch. The flange where the floor gets plug welded to the long can't be perforated with a pic, but it's not looking very good (the silver metal in the pic is remnants of the patch that was scabbed onto it). If I cut a piece of 18 gauge per the lines I've drawn and butt weld it, along with the long repair work etc. I will be doing, will that provide sufficient strength in the area of the jacking donut? Or, do I need to add a second layer somehow to strengthen this patch? A butt weld ground and blended will be just fine for repairing this area.. |
doug_b_928 |
May 25 2017, 05:17 PM
Great, thank you very much for your response!
Lo-Fi Version | Time is now: 2nd May 2024 - 07:47 AM |
