camber settings, What are you guys running? |
914dave |
May 25 2017, 10:47 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
ChrisFoley |
May 26 2017, 04:40 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I don't like to use more than 3/4 degree negative camber on a dual use street car. Tire wear on the inside edge is drastically increased to achieve a modest improvement in corner grip.
More often I set street cars up at 1/2 degree negative all around. |
914dave |
May 26 2017, 06:10 AM
I don't like to use more than 3/4 degree negative camber on a dual use street car. Tire wear on the inside edge is drastically increased to achieve a modest improvement in corner grip. More often I set street cars up at 1/2 degree negative all around. Thanks Chris. This is exactly what I was looking for. Performance gains vs tire wear. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:33 PM |
