camber settings, What are you guys running? |
914dave |
May 25 2017, 10:47 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
PlaysWithCars |
Jun 27 2017, 11:43 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
For me the cars have always been driven on the street but only a limited number of miles each year. The tires are going to get too old long before they get worn out from excessive camber. So, I've run max camber (~-1.7 deg up front, I don't remember but think about the same in the rear), slight toe out up front, and zero toe in the rear. It makes the car responsive and fun to drive. I've had little to no problem with tramlining (following grooves in the road) with this set up.
Lots of camber will wear the inside edges of the tire and it will be accelerated if you run much toe. I've found more camber, less toe to be a good set up with moderate wear and good performance. Depending on how many miles you'll be putting on it each year, I say go for the most performance you can w/o burning through tires before they they are too old and need to be replaced due to age. |
ChrisFoley |
Jun 28 2017, 07:08 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... Depending on how many miles you'll be putting on it each year, I say go for the most performance you can w/o burning through tires before they they are too old and need to be replaced due to age. The best street performance is available at camber settings of less than 3/4 degree negative. Only on track with very sticky tires is it possible to get additional performance from increased camber settings. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:15 AM |
