camber settings, What are you guys running? |
914dave |
May 25 2017, 10:47 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
Mark Henry |
Jun 28 2017, 07:29 AM
What do you guys think about doing your own alignments?
There's real cheap tools for setting camber or you could set up something that uses a tilt box. Toe in is easy to make a fixture to do that. I'm asking because I have 4 cars that will need alignment soon and I do at least 1-3 cars a year. The shops are all 60+ minute round trips, up to a couple hours there minimum, so by time I get back a better part of the day is shot. |
LowBridge |
Jun 28 2017, 07:32 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
What do you guys think about doing your own alignments? there's real cheap tools for setting camber or you could set up something that uses a tilt box. Toe in is easy to make a fixture to do that. I'm asking because I have 4 cars that will need alignment soon and I do at least 1-3 cars a year. The shops are all 60+ minute round trips, up to a couple hours there minimum, so by time I get home a better part of the day is shot. with even simply tools this is very easy to do... however and this is the big however, you must have a flat working surface otherwise it's not going to work and this is why I had Chris do mine.. |
Mark Henry |
Jun 28 2017, 07:47 AM
with even simply tools this is very easy to do... however and this is the big however, you must have a flat working surface otherwise it's not going to work and this is why I had Chris do mine.. Yep, I was thinking about that because my floor isn't perfect. My idea on that is bolt plates to the floor in the four corners that are perfectly level. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 08:07 PM |
