camber settings, What are you guys running? |
914dave |
May 25 2017, 10:47 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
Dave_Darling |
Jun 29 2017, 12:21 AM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think you meant front toe-out to improve turn-in. Rear toe-out gives you a car where the back wants to steer the front...
--DD |
Lo-Fi Version | Time is now: 15th May 2024 - 02:43 PM |
