camber settings, What are you guys running? |
914dave |
May 25 2017, 10:47 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Won't be long til we're off to alignment and corner balance. The car is mostly street use and probably a monthly autocross. 21mm bars up front and 180# adjustable coilovers in the rear. 23mm front sway bar and the front spindles are raised 19mm. Torque bias limited slip and a stock rear sway bar.
Are you guys running stock settings? I don't mind a little more aggressive but it's not an all out competition car. I'll sacrifice a little more tire wear for performance. What have you guys run that works? |
Dave_Darling |
Jun 29 2017, 12:10 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I have heard from folks on the Bird Board that the bathroom scale solution does not work very well. It is sensitive to exactly how you set it up, and difficult to get repeatable measurements.
I didn't check the link, so it is possible that this is a better version than discussed on the Bird's Racing BBS, and doesn't have those issues, but it's definitely something to at least think about. --DD |
Lo-Fi Version | Time is now: 15th May 2024 - 06:54 AM |
